Turn on output pin
Results 1 to 5 of 5
    Jun 2006
    Default Turn on output pin
    I have two sensors to control one rele.
    One for volt and one for temperature.
    When the temperature (Vout) exceed the limit (P3) turn on the rele
    and if the temperature is below the limit turn of the rele.
    I want now , if the volt (value2) exceed the limit (P5) turn on the rele
    and stay on for forever, but i don't know how
        If Vout >= P3 then                'Temp
            PORTA.0=1
            Pause 1000
            PORTA.0=0
        If value2 >= P5 then  PORTA.0=1    'Volt
    P3 and P5 is the limit
    How about this:
    Relay var PortA.0                       'Relay connected to PortA.0
    Latch var bit
    ON CON 1                                'Constant for relay ON
    OFF CON 0                               'Constant for realy OFF
    Latch = 0
    Start:
      If Value2 >= P5 then Latch = 1        'Remember that Value2 has exceeded limit
      If (Vout >= P3) OR (Latch = 1) then   'Relay ON if Vout is over limit OR Value2 is or have been.
        Relay = ON
        Relay = OFF
      EndIf
      Pause 1000
    Goto Start
    Once Value2 is bigger than (or equal to) P5 the relay will turn ON and stay ON forever. Otherwise the state of the relay depends on Vout.
    /Henrik Olsson.
    Jun 2006
    How about this:
    Latch var bit
    Latch = 0
    Start:
        Relay = ON
        Relay = OFF
      EndIf
      Pause 1000
    Goto Start
    /Henrik Olsson.
    Thank you
    If i want to add two more value
    If value >= P1 then PORTA.0=1
    If value1 >= P2 then PORTA.0=1
    how to make this;
    Hi Savnik,
    Looks like a job for select case - see page 129 in . . dare I say . .the manual.
    Jun 2006
    Hi Savnik,
    I read the select case in page 129 , but i cann't understand how to write the code , because i have many variables
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. Help changing CCP3 output pin
    Last Post: - 15th July 2008, 03:30
  3. Microcontroller with 2 way paging application problem
  4. Serious Serial Situation Setbacks...
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
