LCD and PIC18F4550
Results 1 to 16 of 16
    Mar 2007
    West Hollywood, CA
    Question
    I tried that:
    DEFINE OSC 48
    ADCON1 = $0F
    ' set variables:
    x VAR BYTE
    steps VAR WORD
    stepArray VAR BYTE(4)
    clear
    TRISB = %11110000
    PORTB = 255
    Pause 1000
    stepArray[0] = %00001010
    stepArray[1] = %00000110
    stepArray[2] = %00000101
    stepArray[3] = %00001001
    if 1 = 1 then
    steps = steps + 1
    steps = steps - 1
    PORTB = stepArray[steps //4]
    pause 2
    GoTo main
    Mar 2007
    West Hollywood, CA
    you may wonder about some of the code. It was originally written for a button to determine the direction, but to make it less confusing, I just say 1=1 to get to the heart of the code. I could have taken it out, but it will go back in.
    -Sterling
    I figured as much.
    When I look at this page ...
    http://www.sas.org/E-Bulletin/2002-0...ctro/body.html
    Your phase sequence seems to be different.
    I guess it depends on which pin connects to which phase.
    Might try a little more than 2ms delay to start too.
    Mar 2007
    West Hollywood, CA
    Question
    I've monkeyed around with the delay, gone all the way up to 20ms.
    I had this wiring working on another PIC, so I am pretty sure it should work, unless that program, written ASM was sending different bytes out the port.
    I'll check, if I can decipher it.
    Cheers,
    Sterling
    Mar 2007
    West Hollywood, CA
    So I looked into the ASM code that sucessfully drove the motor, and made the BYTE output changes to match, but still no luck.
    I'm wondering if it could have something to do with the chips high speed of 48MHz?
    -Sterling
    could be many things, any code, link, picture, D-D bra are welcome
    Mar 2007
    West Hollywood, CA
    Red face
    OKay, attached is the latest version of code, and my config settings. The config settings work for both LCD output and USB connection.
    -Sterling
  1. DS18B20 and PIC18F4550
    By sjohansson in forum mel PIC BASIC Pro
    Last Post: - 19th April 2006, 20:57
  2. Replies: 5
    Last Post: - 26th March 2006, 20:26
