mouse demo program PIC18F4550
Results 1 to 6 of 6
    Mar 2007
    West Hollywood, CA
    Cool mouse demo program PIC18F4550
    USBMOUSE.BAS isn't working with my PIC18F4550.
    I had it working without incident on a PIC16C675, so I'm not sure what I have wrong now.
    The only differnce is that I have a 20MHz crystal on the OSC pins, instead of 6MHz.
    I have a 1.5K resistor from VUSB to D- and GND.
    The descriptor file is set correctly, and I have UCFG_VAL set for low-speed USB.
    Now, I did notice that the demo code has a "DEFINE OSC 48" in it, but I'm using a 20MHz crystal, which the text file said is what th edemo programs are set for.
    Any ideas on what could be wrong?
    I've uploaded my config settings
    Do a search for "USBDemo"...answer is right there...
    Mar 2007
    West Hollywood, CA
    Cool
    I found the settings on another post, but still have no luck. Here's what I got: see attached.
    The only thing I don't have ON as in the other posting is WRTB. I'm afriad to protect the boot table, for fear I'll never be able to change it.
    Thoughts, maybe it is a wiring issue.
    -Sterling
    Quote Originally Posted by SterlingY View Post
    -Sterling
    So, you're running the PIC at 20mhz, and the code is defined as running at 48mhz and yet the PLL's are configured for a 20mhz oscillator.
    Nope...no idea what the problem is...
    Mar 2007
    West Hollywood, CA
    According to this thread: http://www.picbasic.co.uk/forum/show...85&postcount=4
    This is how the code and chip should be configured.
    It says: DEFINE OSC 48 ' 20MHz crystal with HSPLL enabled = 48MHz
    -Sterling
    Mar 2007
    West Hollywood, CA
    Smile
    Problem solved!!!!
    The config settings on the other thread are correct. I had removed a capacitor and forgotten. That's what happens when you spend 8 hours on one thing.
    Cheers,
    Sterling
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. USB Optical mouse as motor encoder
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 24th August 2008, 16:09
  3. Making Program Code Space your playground...
  4. need help simulating PS/2 mouse
    By peterdeco1 in forum mel PIC BASIC Pro
    Last Post: - 9th December 2007, 22:49
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 15:30
