serout pic16f84 different than pic16f818
Results 1 to 7 of 7
    Default Quandry???
    I'm trying to get my pic 16f818 to transmit characters to a serial LCD. When I use the same code on f84 chip it works fine. However, when I try it on a f818 it sends a different character. I used a logic analyzer to check out what's going on. It looks as if the start bit is longer on the f84. I thought by default it sent data 8N1 not matter what chip your using. Is there any defines I don't know about? Thanks for any help.
    INCLUDE "BS2DEFS.BAS"
    @ DEVICE INTRC_OSC_NOCLKOUT,MCLR_OFF
    OSCCON=$60
    ADCON1=6
    <font color=red>HIGH PORTB.0</font color>
    sleep 2
    low PORTA.2
    begin:
    serout PORTB.0,N2400,[12]
    SLEEP 2
    SEROUT2 PORTB.0,N2400, [68]
    SLEEP 2
    LOW PORTA.2
    goto begin
    <font color=blue><b>You are calling on your serial output pin to go high.
    What's that about? Also you have used serout AND serout2, so yes you are using serout2, I suspect that's why skimask directed you to page 140. I am curious about the high portB.o command though. I would be inclined to eliminate it and do something like this</font color>
     SEROUT PortB.0,N2400,[254,128,"68"]
    I am really curious as to why you would use INCLUDE "BS2DEFS.BAS" instead of INCLUDE "modedefs.bas" since you are using PICs and not Stamps.
    JS
    Joe it's perfectly usual to set the Serial pin to it's normal state. When you start the PIC and just set the TRIS register, you couldn't know at which level they will be.
    Here there's no TRIS setting, but HIGH take care of it. Too bad, it will need LOW instead for Inverted mode.
    Do a simple test with that Code, monitor the PORTB.0 level before the SEROUT, and after the SEROUT. There's chance it will be different, thus this may 'fart' the First data you send.
    Another thing, this PIC have a nice OSCCON register that allow you to know when the internal OSC is stable. You should wait until it is stable unless you may again screw the baudrate.
    Again, it use a internal OSC which are usually pretty poor for any reliable serial communication. At least you should tune it by changing the OSCTUNE register value. Why it worked with a F84... because of the EXTERNAL osc.
    If you have only 1 serial output, There's no advantage to use SEROUT, you should try DEBUG.
    PBP SLEEP use the WatchdogTimer, and you don't have it enable in your config fuses. So i doubt it may work UNLESS you haven't comment the PBP default in the PBP .INC file. WhyNot using PAUSE instead?
    For safety sake, you should wait at little bit after you set the SerialPinIdle level, let's say 50mSec
    try this untested one
            DEVICE PIC16F818, INTRC_OSC ,MCLR_OFF   ,LVP_OFF
            DEVICE PIC16F818, WDT_ON    ,PWRT_ON    ,BOD_ON
            DEVICE PIC16F818, DEBUG_OFF ,CCPMX_OFF
            DEVICE PIC16F818, CPD_OFF   ,WRT_OFF    ,PROTECT_OFF
            '       Internal OSC config
            OSCCON=$60                  ' Internal OSC=4MHZ
            WHILE OSCCON.2=0 : WEND     ' wait until frequency is stable
            '       I/O config
            TRISB=0                     ' PORTB=out
            TRISA=0                     ' PORTA=out
            ADCON1=6                    ' disable ADCs
            '       Softare Serial comm setup
            DEFINE DEBUG_REG PORTB      ' Debug pin port
            DEFINE DEBUG_BIT 0          ' Debug pin bit
            DEFINE DEBUG_BAUD 2400      ' Debug baud rate
            DEFINE DEBUG_MODE 1         ' Debug mode: 0 = True, 1 = Inverted
            DEFINE DEBUG_PACING 1000    ' Debug character pacing in us
            '                       Program Start
            '       Hardware init
            PORTA=0                     ' clear PORTA
            PORTB=0                     ' clear PORTB
            pause 50                    ' safe statup delay
    Start:
            debug "Text or data, or whatever else written in PBP manual"
            PAUSE 250
            GOTO START
    Steve,
    All the code and text above the <font color=blue><b>blue text, is the other guys</font color></b> I was just trying to get explanation as to why the high port command, Thank you for the explanation, it will help my applications later. <b>Interestingly enough I tried out debug last night for the first time!</b> I have never used internal osc. on a project, and taking your warnings I likely will never use it to serial communicate. Frankly, what is training? Benefitting from the experience of others. Albert Einstein said," all knowlege is trial and error ". Very interesting to learn about pic's ability to wait for internal osc to stabalize.
    Thank You again
    JS
    Mar 2007
    Default Thanks ya'll
    I've decided to heed your advice and use an external oscillator. Works great now without having to put in timing delays and such.
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
    Last Post: - 13th December 2008, 18:11
  4. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 05:26
  5. Replies: 11
    Last Post: - 13th July 2005, 20:26
