LCDOUT probs
Results 1 to 10 of 10
Thread: LCDOUT probs
    Sep 2005
    Default LCDOUT probs
    HI there this is the first time i have tried driving an lcd i have read the manual but i still canot get the thing working.
    Here is my code
    start:
    pause 1000 'wait for lcd to start up
    lcdout $FE, 1 'clear screen
    lcdout $FE, 2 'return to home
    lcdout $FE, 1, "Welcome" 'write welcome on the screen
    pause 2000
    goto start
    end if
    i have built the circuit based on the one in the pbp maunal
    but still no luck, nothing, i have checked all my connections but still nothing the lcd i am using is from here http://www.maplin.co.uk/module.aspx?...9&doy=9m3#spec
    please can some one please steer me in the right direction, thank you for your time.
    Sep 2005
    Campbell, CA
    Make certain you have all your DEFINES set up properly to tell PBP just
    what pins you have connected to what.
    Also, use some command and data delays.
    Below is a header file I use. It works with every display I hook up.
    You will have to change your pin definitions, of course.
    DEFINE LCD_DREG PORTH
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTH
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG PORTJ
    DEFINE LCD_EBIT 2
    DEFINE LCD_RWREG PORTH
    DEFINE LCD_RWBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 3000
    DEFINE LCD_DATAUS 300
    Charles Linquist
    Quote Originally Posted by Jhdgkss View Post
    start:
    pause 2000
    goto start
    end if
    Is that your whole program?
    Sep 2005
    yes thats the whole code. how do i set the define's so that my data will use portA like in the manual and the enable is on portb.3 i thought it would just adopt the standard setting automatacly unless told otherwise. iam useing a pic64f84a
    Sep 2005
    Campbell, CA
    Just follow my example. It should be pretty explanatory.
    In my example, I use PORTH as the data register
    The LSbit is tied to bit 0 (PORTH.0)
    The R/S pin is tied to PortH.5
    E is tied to PORTJ.2 etc
    Charles Linquist
    Mar 2007
    Charles,
    Is there any particular reason that the 4 data bits and the controlling pins (ie. E, RW, RS) should be on different ports as I seem to see in most examples??
    Or can they be "defined" to the same port without problem?
    Hoops
    Sep 2005
    Campbell, CA
    They can be defined on the same port. The only limitation that I'm aware of is that the DATA lines must start on a nybble boundary (either on bit 0 or 4)of a port.
    Charles Linquist
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 08:31
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 03:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
