LCDOUT probs
Results 1 to 10 of 10
Thread: LCDOUT probs
    Sep 2005
    Default LCDOUT probs
    HI there this is the first time i have tried driving an lcd i have read the manual but i still canot get the thing working.
    Here is my code
    start:
    pause 1000 'wait for lcd to start up
    lcdout $FE, 1 'clear screen
    lcdout $FE, 2 'return to home
    lcdout $FE, 1, "Welcome" 'write welcome on the screen
    pause 2000
    goto start
    end if
    i have built the circuit based on the one in the pbp maunal
    but still no luck, nothing, i have checked all my connections but still nothing the lcd i am using is from here http://www.maplin.co.uk/module.aspx?...9&doy=9m3#spec
    please can some one please steer me in the right direction, thank you for your time.
    Sep 2005
    Campbell, CA
    Make certain you have all your DEFINES set up properly to tell PBP just
    what pins you have connected to what.
    Also, use some command and data delays.
    Below is a header file I use. It works with every display I hook up.
    You will have to change your pin definitions, of course.
    DEFINE LCD_DREG PORTH
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTH
    DEFINE LCD_RSBIT 5
    DEFINE LCD_EREG PORTJ
    DEFINE LCD_EBIT 2
    DEFINE LCD_RWREG PORTH
    DEFINE LCD_RWBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 3000
    DEFINE LCD_DATAUS 300
    Charles Linquist
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by Jhdgkss View Post
    start:
    pause 2000
    goto start
    end if
    Is that your whole program?
    Sep 2005
    yes thats the whole code. how do i set the define's so that my data will use portA like in the manual and the enable is on portb.3 i thought it would just adopt the standard setting automatacly unless told otherwise. iam useing a pic64f84a
    Sep 2005
    Campbell, CA
    Just follow my example. It should be pretty explanatory.
    In my example, I use PORTH as the data register
    The LSbit is tied to bit 0 (PORTH.0)
    The R/S pin is tied to PortH.5
    E is tied to PORTJ.2 etc
    Charles Linquist
    Mar 2007
    Charles,
    Is there any particular reason that the 4 data bits and the controlling pins (ie. E, RW, RS) should be on different ports as I seem to see in most examples??
    Or can they be "defined" to the same port without problem?
    Hoops
    Sep 2005
    Campbell, CA
    They can be defined on the same port. The only limitation that I'm aware of is that the DATA lines must start on a nybble boundary (either on bit 0 or 4)of a port.
    Charles Linquist
    Sep 2005
    hi thanks for your replys.
    so to alter this code to run on a pic16h84 witch has o port h only A and B i make the following changes
    start:
    DEFINE LCD_DREG PORTA
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 3
    DEFINE LCD_RWREG PORTA
    DEFINE LCD_RWBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    LCDOUT $FE, 1
    LCDOUT $FE, 2, “Hello”
    goto Main
    with connections
    1 - VSS
    2 - VDD
    3 - VC
    4 - RS - PortA.4
    5 - R/W - portA.4
    6 - E - PortB.3
    7 - Db0 -open
    8- DB1 - open
    9 - DB2 - open
    10 DB3 - open
    11 DB4 - portA.0
    12 DB5 - portA.1
    13 DB6 - portA.2
    14 DB7 - portA.3
    could some one please have a look at my data sheet for the display and check hat this setup will work with it
    http://www.maplin.co.uk/Media/PDFs/N28AZ.pdf
    thank you for your patience your help has shed a lot of light on the subject of lcd's for this newbie.
    Assuming you have a Pull-Up resistor on the PORTA.4 pin, i think you MUST set them to LOW yourself.
    You don't need to use the LCD R/W pin, just ground it and remove the according DEFINEs
    AND you have two things on PORTA. RW and RS
    Sep 2005
    hi there thanks for the reply. ia have resistor on that pin
    i have noticed the prob with rw and rs
    here are my changes in code
    start:
    portA = low
    PortB = low
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    LCDOUT $FE, 1
    goto Main
    with connections
    1 - VSS
    2 - VDD
    3 - VC
    4 - RS - PortA.4
    5 - R/W - Ground
    6 - E - PortB.3
    7 - Db0 -open
    8- DB1 - open
    9 - DB2 - open
    10 DB3 - open
    11 DB4 - portA.0
    12 DB5 - portA.1
    13 DB6 - portA.2
    14 DB7 - portA.
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 08:56
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 08:31
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 03:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 16:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
