Hysteresis.. How to do it??
Results 1 to 8 of 8
    Mar 2007
    Default Hysteresis.. How to do it??
    First up I am extremely new to PICs and PICBasic and am reading and experimenting a LOT trying to fast track to an ulitmate project. As a result, I am breaking the "big picture" down into little pieces and trying to work out as much as I can myself - so please know that I *really* have tried to nut this one out..!!!!!
    I am using a 16F877 that measures a variable resistor/voltage divider (with the bigger picture being to measure a thermistor) and depending on a user set variables.. switch a LED on or off..
    The thing I need/want to do is have the LED switch on at say 100 degrees and then switch off only when the temperature drops below 80 degrees... I believe this is called Hysteresis..??!!?
    But I am stumped at how to do this..?
    I've tried using the following:
    IF temp >= 100 THEN GOSUB ledon
    IF temp <= 80 THEN GOSUB ledoff
    Can anyone shed any light on this..??
    Hoops
    Jun 2005
    Thumbs up
    Hoops,
    Your example should work fine. I have used similar code and it works great. I have controlled temp with 1 to 3 degrees F hysteresis in harsh/noisy environments. You could use the ADC equivalent for 100F and 80F and skip linearizing the thermistor. I use 10k resistor/10K thermistor/.1uF cap and Darrel Taylor's excellent averaging routine
    http://www.picbasic.co.uk/forum/show...67&postcount=5.
    Mark
    Mar 2007
    Thanks for the reply Mark
    The problem with my code is that as soon as the input falls below the upper temperature setting, it switches off...
    Rather I want it to wait until it falls below the lower setting - here is my full code - maybe that will explain things.
    Define  LCD_DREG        PORTD
    Define  LCD_DBIT        4
    Define  LCD_RSREG       PORTE
    Define  LCD_RSBIT       0
    Define  LCD_EREG        PORTE
    Define  LCD_EBIT        1
    TRISA = %00001011
    trisd = %00000000
    temp        var     byte                        'temp variable
            ADCON1 = 4                              ' Set PortA 0, 1, 3 to A/D inputs
            Low PORTE.2                             ' LCD R/W line low (W)
            Pause 100                               ' Wait for LCD to start
    mainloop:
            ADCON0 = $41                            ' Set A/D to Fosc/8, Channel 0, On
            Pauseus 50                              ' Wait for channel to setup
            ADCON0.2 = 1                            ' Start conversion
            Pauseus 50                              ' Wait for conversion
            temp = ADRESH                           ' ADC output address = Temp
            Lcdout $fe, 1, "Water Temp = ", #temp,"'F" ' Send to LCD
            if temp >= 80 then gosub fan1on         ' fan ON at 80
            If temp <> 70 then gosub fan1off        ' fan OFF at 70
            Pause   100                             ' Sample 10 times a second
            Goto    mainloop                        ' Repeat
    fan1on
            portd.0 = 1
            lcdout $fe,$94, "Fan 1 ON"
    fan1off
            portd.0 = 0
    I hope you can help..
    Can't wait until I can afford the full PicBasic and then I can get stuck into putting this all together - being a broke student sucks.
    Hoops
    [QUOTE=hoopstar;34279]
    Look at your original code...it doesn't make any sense.
    If the temp is above 80, the fan kicks on...BUT...
    if the temp is anything EXCEPT 70, the fan kicks off...
    Change it to:
    if temp => 80 then gosub fan1on
    if temp <= 70 then gosub fan1off
    Which is basically what you had in the first place. But I think you are sampling far too often. And I'd also throw a counter in there somewhere...something like if the temp is below 70 and you've checked XX number of times, then turn the fan off. (same thing with fan on). That way it'll keep from clicking on and off too often when the temp is right at the switch point.
    I think the answer to you problem would be to make fan1on a loop not a return.
    Stay in that loop until the temp drops below the set point.
    Move the ADC commands to a GOSUB and then you can sample from anywhere and have less code.
    This example is using two probes on a 18F4320.
    CHECK:
    T1 = temp1*2
    T2 = temp2*2
    LCDOUT $FE,1,"INSIDE ",#T1
    lcdout $FE,$C0,"OUTSIDE ",#T2
    gosub getT1
    gosub getT2
    if T1 > T2 + 10 then BLINK
    goto CHECK
    BLINK:
    high PORTD.0
    LOW PORTD.1
    low PORTD.0
    HIGH PORTD.1
    if T1 = T2 THEN DARK
    gosub getT1
    gosub getT2
    goto BLINK
    DARK:
    low PORTD.0
    LOW PORTD.1
    goto CHECK
    getT1:
    ADCON0=$1 '%00000001 AN0
    gosub getAD
    temp1 = ADRESH
    getT2:
    ADCON0=$5 '%00000101 AN1
    gosub getAD
    temp2 = ADRESH
    getAD:
    pause 50
    ADCON0.1 = 1
    pause 50
    Also you could use a variable as a hysterisis.
    hyst_high var byte
    hyst_low var byte
    hyst_low=0
    hyst_high=0
    if temp >= 80+hyst_high then gosub fan1on ' fan ON at 80
    if temp <= 70+hyst_low then gosub fan1off
    fan1on:
    hyst_high=5
    hyst_low=0
    fan10ff:
    hyst_low=5
    hyst_high=0
    Wink
    Quote Originally Posted by markedwards View Post
    Mark
    Hi, Mark
    I Read somewhere a ( very ... ) simple Thermistor linearization was to parallel the Thermistor a resistor of the same nominal value ...
    I didn't try, but Worth the test ... no ???
    Mar 2007
    Thumbs up
    I do plan on using GOSUB's but at the moment I am using the demo version of PicBasic and can't really afford to step up to Pro (poor student) so am just qualifying my code/ideas within the line limit of the demo version.
    I *really* appreciate all the help and input on this - thanks guys.
    Hoops
  1. hysteresis control
    By hyeniyurt in forum Off Topic
    Last Post: - 25th February 2009, 23:37
  2. Replies: 14
    Last Post: - 26th September 2007, 06:41
  3. ADC on 12f675?
    By peu in forum mel PIC BASIC Pro
    Last Post: - 16th March 2005, 18:44
