Here is my first try on PID control. Obviously failed...
At the attached schematic is the part of the circuit, essentialy a Voltage stabilizer. The PWM from the PIC drives the Power stage while from the output a voltage sample is returned to the ADC.
Unfortunately there is no control at all. When Setpoint is 0 or 1023 the output is always high (pid_out is 511).
Also I noticed that Direction bit is high when Voltage sample is higher than Setpoint. Is this correct?
Test PIC is F887 driving the internal HPWM.
'** PWM Controller with voltage level feedback
'** 21.11.2010, v.1.0
'** PID Control by Henrik Olsson
DEFINE OSC 8
OSCCON = %01110001 'SET SYSTEM CLOCK SWITCH BIT
;----- Configuration bits ------------------------------------------------
@Line1 = _DEBUG_OFF & _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_ON
@Line2 = _CP_OFF & _MCLRE_OFF & _PWRTE_ON & _WDT_ON & _INTRC_OSC_NOCLKOUT
@ __CONFIG _CONFIG1, Line1 & Line2
@ __CONFIG _CONFIG2, _WRT_HALF & _BOR40V
PORTA=0:PORTB=0:PORTC=0:PORTD=0:PORTE=0
TRISA=%00101101
TRISB=%00000000
TRISC=%10000000
TRISD=%00000011
TRISE=%00000000
OPTION_REG.0=1 'PSA0 PRESCALER SELECT 1:1 TO 1:256
OPTION_REG.1=1 'PSA1
OPTION_REG.2=1 'PSA2
OPTION_REG.3=0 'PRESCALER TO: 1->WDT, 0->TMR0
OPTION_REG.4=0 'T0SE SOURCE EDGE 1->H TO L, 0->L TO H
OPTION_REG.5=0 'T0CS 1->FROM RA4, 0->FROM INT. CLOCK
OPTION_REG.6=0 'INT EDGE SELECT 0->H TO L, 1->L TO H
OPTION_REG.7=0 'PULL UP 1->DISABLE, 0->ENABLE
WPUB = %00111111
'DEFINE HSER_RCSTA 90h
'DEFINE HSER_TXSTA 24h
'DEFINE HSER_BAUD 19200
'DEFINE HSER_CLROERR 1 ' Clear overflow automatically
'************************* Define LCD parameters
ADCON0 = %11000001
ADCON1 = %10000000 'Set PORTA/E analog/digital, right justify result
ANSEL = %00101101 'lower port A as Analog input
ANSELH = %00000000 'all others Digital inputs
DEFINE ADC_BITS 10 'Number of bits in Adcin result
DEFINE ADC_CLOCK 3 'ADC clock source (rc = 3)
DEFINE ADC_SAMPLEUS 50
but_0 var portd.0
but_1 var portd.1
'**** Initialization
clear
ADValue VAR WORD '<---This is your variable.
Setpoint VAR WORD '<---This is your variable.
Direction var PortB.7 '<---Direction bit to motor driver
p_gain var word
i_gain var word
d_gain var word
Setpoint=200
INCLUDE "incPIDv1.5.pbp" 'Include the PID routine.
'These variables are declared by the incPID routine but
'the user needs to assign values to them.
' pid_Kp = $0700 'Set Kp to 7.0
' pid_Ki = $0080 'Set Ki to 0.5
' pid_Kd = $0225 'Set Kd to 2.14
pid_Ti = 8 'Update I-term every 8th call to PID
pid_I_Clamp = 100 'Clamp I-term to max ±100
pid_Out_Clamp = 511 'Clamp the final output to ±511
Start:
Gosub analog 'Get speed from tacho and setpoint pot - NOT SHOWN HERE.
pid_Kp=p_gain:pid_Ki=i_gain:pid_Kd=d_gain
pid_Error = Setpoint - value 'Calculate the error
Gosub PID 'Result returned in pid_Drive
Direction = pid_Out.15 'Set direction pin accordning to sign
pid_Out = ABS pid_Out 'Convert from two's comp. to absolute
HPWM 1, pid_Out, 500 'Set PWM output
'Just for monitoring
serout2 portc.6,16468, [27,"[10;0H","P:",dec5 p_gain," I:",dec5 i_gain," D:",dec5 d_gain," PID out:",#pid_out," ",27,"[12;0H","Vout:",dec5 value," SP:",dec5 setPoint," pid_err:",dec5 pid_error, 27,"[14;0H","Direction: ",#direction]
Goto Start '...and do it again.
analog:
adcin 0,value
gosub average
adcin 2,p_gain
p_gain=p_gain<<2
adcin 3,i_gain
i_gain=i_gain>>2
adcin 4,d_gain
d_gain=d_gain<<2
'Two digital inputs for setting Setpoint level
if !but_0 then
if Setpoint>0 then
setpoint=setpoint-2
if !but_1 then
if Setpoint<1021 then
setpoint=setpoint+2
I am using 3 Analog inputs to set the P,I,D values as it is clear from the analog subroutine.
Whatever the values the pid_out stays at 511 and plays a litle at the point where Setpoint is almost equal to the Vout level.
Any inputs welcome.
