PID-filter routine (2nd try).
Results 1 to 40 of 132
    The very first thing to tend to, IMHO, is to make the update rate as stable as possible - it is very important for stability. If you haven't already seen it, here's a pretty good article on digital PID filter implementation. It's a good read even if you're not actually writing the PID filter code - just using it.
    Keep at it and keep us posted!
    I recall downloading that article, but did not read it. Will do.
    My pre-PID implementation was based on a loose control loop like this one:
    if out_value < (setpoint - 1) then
        pwm_signal=pwm_signal+1
    if out_value > (setpoint + 1) then
        pwm_signal=pwm_signal-1
    It is a very simple idea that gives also a hysteresis of +/-2 points. So if the out_value is within the "dead band" nothing happens.
    The down side is that, depending on the overall loop it may take too long to reach the setpoint and also may do some oscillations also if there is delay getting the correct analog feedback.
    My first impressions using the PID is that has the potential to be very fast and accurate, despite the fact I did not managed to make it work reliable yet.
    Will come back after correcting the setup.
  1. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 02:57
  2. 2nd order Low-pass passive RC filter on PWM
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 29th January 2009, 20:03
  3. Atod Digital Filter
    By GeoJoe in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 18:04
  4. PID controller in 16F737
    By joeri in forum mel PIC BASIC
    Last Post: - 24th June 2006, 12:39
  5. 2nd Order Digital Filter for 24-bit
    By sefayil in forum mel PIC BASIC
    Last Post: - 2nd December 2005, 22:55
