PID-filter routine (2nd try).
Results 1 to 40 of 132
    Default My first try on PID...
    Here is my first try on PID control. Obviously failed...
    At the attached schematic is the part of the circuit, essentialy a Voltage stabilizer. The PWM from the PIC drives the Power stage while from the output a voltage sample is returned to the ADC.
    Unfortunately there is no control at all. When Setpoint is 0 or 1023 the output is always high (pid_out is 511).
    Also I noticed that Direction bit is high when Voltage sample is higher than Setpoint. Is this correct?
    Test PIC is F887 driving the internal HPWM.
    '**		PWM Controller with voltage level feedback
    '**     21.11.2010, v.1.0
    '**     PID Control by Henrik Olsson
    DEFINE OSC 8
    OSCCON = %01110001 'SET SYSTEM CLOCK SWITCH BIT
    ;----- Configuration bits ------------------------------------------------
    @Line1 = _DEBUG_OFF & _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_ON
    @Line2 = _CP_OFF & _MCLRE_OFF & _PWRTE_ON & _WDT_ON & _INTRC_OSC_NOCLKOUT
    @ __CONFIG _CONFIG1, Line1 & Line2
    @ __CONFIG _CONFIG2, _WRT_HALF & _BOR40V
    PORTA=0:PORTB=0:PORTC=0:PORTD=0:PORTE=0
    TRISA=%00101101
    TRISB=%00000000
    TRISC=%10000000
    TRISD=%00000011
    TRISE=%00000000
    OPTION_REG.0=1		'PSA0 PRESCALER SELECT 1:1 TO 1:256
    OPTION_REG.1=1		'PSA1
    OPTION_REG.2=1		'PSA2
    OPTION_REG.3=0		'PRESCALER TO: 1->WDT, 0->TMR0
    OPTION_REG.4=0		'T0SE SOURCE EDGE 1->H TO L, 0->L TO H
    OPTION_REG.5=0		'T0CS 1->FROM RA4, 0->FROM INT. CLOCK
    OPTION_REG.6=0		'INT EDGE SELECT 0->H TO L, 1->L TO H
    OPTION_REG.7=0		'PULL UP 1->DISABLE, 0->ENABLE
    WPUB = %00111111
    'DEFINE HSER_RCSTA 90h
    'DEFINE HSER_TXSTA 24h
    'DEFINE HSER_BAUD 19200
    'DEFINE HSER_CLROERR 1 ' Clear overflow automatically
    '************************* Define LCD parameters
    ADCON0 = %11000001
    ADCON1 = %10000000	'Set PORTA/E analog/digital, right justify result
    ANSEL  = %00101101  'lower port A as Analog input
    ANSELH = %00000000  'all others Digital inputs
    DEFINE ADC_BITS 10  'Number of bits in Adcin result
    DEFINE ADC_CLOCK 3  'ADC clock source (rc = 3)
    DEFINE ADC_SAMPLEUS 50
    but_0           var portd.0
    but_1           var portd.1
    '****                            Initialization
    clear
    ADValue VAR WORD                     '<---This is your variable.
    Setpoint VAR WORD                    '<---This is your variable.
    Direction var PortB.7                '<---Direction bit to motor driver
    p_gain      var word
    i_gain      var word
    d_gain      var word
    Setpoint=200
    INCLUDE "incPIDv1.5.pbp"                 'Include the PID routine.
        'These variables are declared by the incPID routine but
        'the user needs to assign values to them.
    '    pid_Kp = $0700                     'Set Kp to 7.0
    '    pid_Ki = $0080                     'Set Ki to 0.5
    '    pid_Kd = $0225                     'Set Kd to 2.14
        pid_Ti = 8                         'Update I-term every 8th call to PID
        pid_I_Clamp = 100                  'Clamp I-term to max ±100
        pid_Out_Clamp = 511                'Clamp the final output to ±511
      Start:
        Gosub analog                        'Get speed from tacho and setpoint pot - NOT SHOWN HERE.
        pid_Kp=p_gain:pid_Ki=i_gain:pid_Kd=d_gain
        pid_Error = Setpoint - value     'Calculate the error
        Gosub PID                          'Result returned in pid_Drive
        Direction = pid_Out.15             'Set direction pin accordning to sign
        pid_Out = ABS pid_Out              'Convert from two's comp. to absolute
        HPWM 1, pid_Out, 500             'Set PWM output
        'Just for monitoring
        serout2 portc.6,16468, [27,"[10;0H","P:",dec5 p_gain,"  I:",dec5 i_gain,"  D:",dec5 d_gain,"  PID out:",#pid_out,"    ",27,"[12;0H","Vout:",dec5 value,"  SP:",dec5 setPoint,"  pid_err:",dec5 pid_error, 27,"[14;0H","Direction: ",#direction]
    Goto Start                           '...and do it again.
    analog:
        adcin 0,value
        gosub average
        adcin 2,p_gain
        p_gain=p_gain<<2
        adcin 3,i_gain
        i_gain=i_gain>>2
        adcin 4,d_gain
        d_gain=d_gain<<2
        'Two digital inputs for setting Setpoint level
        if !but_0 then
            if Setpoint>0 then
                setpoint=setpoint-2
        if !but_1 then
            if Setpoint<1021 then
                setpoint=setpoint+2
    I am using 3 Analog inputs to set the P,I,D values as it is clear from the analog subroutine.
    Whatever the values the pid_out stays at 511 and plays a litle at the point where Setpoint is almost equal to the Vout level.
    Any inputs welcome.
    Ioannis,
    I think you need to limit the pid_Out values to only positive numbers, and discard the negative values instead of converting them to positive ones.
    The way you have it ... the more it tries to reduce the voltage, the higher the output goes.
    After it gosubs to the PID routine ... Try this ...
        IF pid_Out.15 THEN pid_Out = 0   ' limit to positive values
    Hi Ioannis,
    I'll just second what Darrel said. For unidirectional control, ie when you can only apply more or less power, not remove power from your "plant" you can't have the output swing negative (which the ABS convert to positive again).
    The example was for controlling a motor where the direction signal basically controls the polarity and the applied torque is controlled by a PWM signal corresponding to the absolute value of the PID signal. That way torque can be applied in both directions.
    In your case you can only apply more or less power, you can't 'reverse' or remove 'power'. Because of that you can't allow negative 'drive'.
    As fir the polarity of the direction bit, that's just a matter of matching it to the hardware I used at the time. If I reversed the polarity of the motor I'd have to reverse the "polarity" of the direction signal. Again, you don't need it in this application.
    Ok, thanks both. I was stupid.
    Now, I 've got a wonderful oscillator!
    No matter the level of P,I,D (except for 0) it does oscillate.
    I suppose it is a matter of tuning, but even with the trimmer as analog inputs to the P,I,D variables, it seems hard to fine tune it.
    When I think I done it, after a power cycle it start again at a rate of 2-5Hz.
    Oh, and clamp the output to 255 for the HPWM command.
    You may want to use 10-bit PWM for finer control.
    Hi Darrel.
    Yes I did clamp the output to 255 although it was not mentioned in my previous post.
    Is this possible with PBP or do I have to mess directly with the PIC registers?
    My next step will be to use MiBAM, as I do not have hardware PWM on the final PIC.
    Start with pid_Ki set to 0. Increase pid_Kp and "bump" the regulator (change the setpoint) do this a couple of times until you see it begin to overshoot or a tendency to oscillate.
    Increase pid_Kd in order to damp out the overshoot.
    Now you can try to increase pid_Kp even further, once again it will overshoot or start to osciallate, follow with pid_Kd.
    This should give you a stable loop but it will most likely never hit the actual setpoint. Slowly increase i pid_Ki to bring the value right up to the setpoint. Increasing pid_Ki will introduce an overshoot which you might should be able to reduce by further increasing pid_Kd.
    With that said it's crucial that you run the PID (read input, run PID, update output) at a constant interval. If the time between updates varies you won't get a stable output.
    (10-bit PWM)
    You might try HPWM10 for now. It's just like HPWM ... almost.
    http://www.picbasic.co.uk/forum/show...7805#post37805
    MIBAM is only 8-bit, but if you only have one output it'll be better to create a higher resolution interrupt driven PWM that could also be a time base for the PID loop.
  1. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 02:57
  2. 2nd order Low-pass passive RC filter on PWM
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 29th January 2009, 20:03
  3. Atod Digital Filter
    By GeoJoe in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 18:04
  4. PID controller in 16F737
    By joeri in forum mel PIC BASIC
    Last Post: - 24th June 2006, 12:39
  5. 2nd Order Digital Filter for 24-bit
    By sefayil in forum mel PIC BASIC
    Last Post: - 2nd December 2005, 22:55
