PID-filter routine (2nd try).
Results 1 to 40 of 132
Threaded View
  1. #11
    Thanks Walter,
    That's its biggest drawback I'd say - the information about it being scattered around several threads on the CNCZone, there are some links in that thread you posted that will take you to other threads about it. There's also some info in this Wiki
    As you probably figured it's not a comercial drive, it was developed by a CNCZone member called Kreutz in effort to get a DIY drive for high(ish) voltage motors where the original UHU-circuit failed to deliver. Kits were made (and probably IS) available by Paul Harshman (tenmetalman) and Irfan Ulla, also on CNCZone at very reasonable prices.
    Being involved since the early stages of the HP-UHU's life I know it pretty well so if you have specific questions regarding it fire away and I'll do my best to answer them. Perhaps it's better to keep it separate from this thread though.
    Thanks!
    EDIT: Thank you for embedding the video by the way!
  1. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 02:57
  2. 2nd order Low-pass passive RC filter on PWM
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 29th January 2009, 20:03
  3. Atod Digital Filter
    By GeoJoe in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 18:04
  4. PID controller in 16F737
    By joeri in forum mel PIC BASIC
    Last Post: - 24th June 2006, 12:39
  5. 2nd Order Digital Filter for 24-bit
    By sefayil in forum mel PIC BASIC
    Last Post: - 2nd December 2005, 22:55
