PID-filter routine (2nd try).
Results 1 to 40 of 132
    Hi Mike,
    There should be no need to edit the include file for this, I don't think.
    All you need to do is calculate the error and send it to the PID-filter, it determines if the error is positive or negative, calculates the "drive" and returns it in the variable PID_Out. You never need to pass any "direction-bit" TO the PID-routine.
    Now, if you're driving something like a heater where you can only deliver power in "one direction" (you can just add more or less heat, you can't remove it) then you simply look at the sign-bit of the PID_Out variable (PID_Out.15) and if it's set (meaning negative "drive" becuse the temperature is too high) you simply set the output to 0.
    OR (and this is probably a better aproach)
    Let's say you know that under normal conditions you need a duty cycle of ~30% to keep the temperature fairly constant. Now you look at the sign of the value in the PID_Out variable and depending on its state you either add or subtract the ABS value of PID_Out from whatever value corresponds to 30% duty cycle. Here you need to make sure you clamp the end value between 0 and 1023 before moving it to the duty cycle register.
    Does this make sense?
    Nov 2009
    Dallas, Texas, USA
    Thanks for the reply.
    Yes, makes sense to me. The process does accept a variable input, not on-off. It's a DC drive that I'm generating a reference voltage for using hardware PWM on a 18F2320 @ 40MHz. Sounds like this should work out fine.
    Once again, thanks!
    Mike
    Yes, what I meant with set the output to 0 was that if the ouput of the PID filter goes negative you "clamp" the dutycycle at 0 since you can't effectively have a negative drive with that system.
    In any case the second aproach should work better. Just a note though, in your first message you wrote:
    Likewise, I'll need to take the output of the PID include that gets passed back to the main process, and add/subtract the new output with the last output based on the direction bit, currently B.15.
    You don't add/subtract the PID filter output from the last output, you add/subtract it from the initial "steady state value". I guess you had that figured out but just in case.
    Let me know how it goes or if there's anything I can do.
    Nov 2009
    Dallas, Texas, USA
    The routine works like a champ!
    Did the first trial run-up today. No problem at all with mono-polar operation. A few tweaks on the constants and it's working great. Need to make a small hardware change in external circuitry, and it'll be wound up.
    Again, thanks! A very handy tool to hang onto.
  1. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 02:57
  2. 2nd order Low-pass passive RC filter on PWM
    By munromh in forum mel PIC BASIC Pro
    Last Post: - 29th January 2009, 20:03
  3. Atod Digital Filter
    By GeoJoe in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 18:04
  4. PID controller in 16F737
    By joeri in forum mel PIC BASIC
    Last Post: - 24th June 2006, 12:39
  5. 2nd Order Digital Filter for 24-bit
    By sefayil in forum mel PIC BASIC
    Last Post: - 2nd December 2005, 22:55
