WRITE data to EEPROM on PIC18F8621
Results 1 to 15 of 15
    Mar 2007
    Melbourne AUSTRALIA
    Default WRITE data to EEPROM on PIC18F8621
    Has anyone had experiance using READ and WRITE on the 18F8621. Using READ I can read the values stored in the EEPROM but I cannot WRITE new values to the internal EEPROM. Why is this? It works on the 16F devices I used in the past.
    I guess this is probably not spacific to this device and assume its due to the migration from 16f to 18f.
    Quote Originally Posted by dschafer View Post
    What version of PBP?
    Mar 2007
    Melbourne AUSTRALIA
    PicBasicPro version 2.4.6.0
    Show us the program that's failing you...
    Mar 2007
    Melbourne AUSTRALIA
    Its a long program, but what i'm trying to do using READ and WRITE is as follows:
    'at the start of the program read these values from EEPROM and place in the variables'
    Read 0, trip_amount[0]
    Read 1, trip_amount[1]
    'so far so good, this works as per usual'
    If S1 = 1 Then
    Read 0, temperary[0]
    Read 1, temperary[1]
    If (trip_amount[0] <> temperary[0]) OR (trip_amount[1] <> temperary[1]) Then
    Write 0, trip_amount[0]
    Write 1, trip_amount[1]
    LCDOut $FE, 1
    LCDOut $FE, $C0 , " SAVING CHANGES"
    Pause 1000
    EndIf
    Goto Menue_2_0
    EndIf
    'I get a SAVING CHANGES on the LCD but the eeprom values dont change'
    well that should work fine, must be something in the rest of the program that isn't being shown, maybe a variable declaration, changing the variable itself in another part of the program, etc.etc.
    Mar 2007
    Melbourne AUSTRALIA
    No, that is not the case, I have checked over the code many times.
    One thing I did notice is when I program the PIC the fuse settings for 'EEPROM table write protect' and 'CONFIG table write protect' are both DISABLED, But when I read the HEX, EEPROM, and fuse data back to the PIC programer both of those setting are ENABLED.
    High likely it's down to your PIC programmer. Which one?
    Mar 2007
    Melbourne AUSTRALIA
    I use the DIY K128 v141204
    and which software?
    Of course it's never the program writer's fault, is it?
    So set them so that the 'protect' options are enabled, read them back, see if they're disabled, and try the program again. Maybe the software for the programmer is bass-ackwards...
    Mar 2007
    Melbourne AUSTRALIA
    and which software?
    MPLAB IDE v7.21
    The K128 programer has its own software
    maybe it worth to visit their forum and ask?
    http://www.websitetoolbox.com/tool/mb/diykit
    Mar 2007
    Melbourne AUSTRALIA
    Smile
    I think you're on the right track.
    Just tried loading the program again, both settings disabled.
    did not power up the PIC
    read rom, eeprom, fuse data, and both setting are already enabled.
    also tried inverting these settings as you sugested but they read the same (enabled)
    will look further at the programmer K128 possibly require updated firmware.
    Thanks for all the help, will let you know how I go.
    Mar 2007
    Melbourne AUSTRALIA
    Default Problem Solved
    Thanks very much for your help. You leed me in the right direction, the direction of the programmer itself. The DIY K128 programmer had a small bug. Installing DIYpack26b2 has fixed the problem.
    PS. Still very happy with the programmer, its a great unit!
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 02:46
  3. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  4. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 19:42
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
