O.T. HEX code disassembly
Results 1 to 2 of 2
    Sep 2005
    Campbell, CA
    Default O.T. HEX code disassembly
    I'm trying to understand a little machine code.
    I have a HEX file that reads
    80EFFEF0...
    The disassembly shows that is equivalent to
    GOTO 0x1fd00 - opcode EF80
    (next line) F0FE
    I understand a little about the reversed order of the bytes, so if I can
    see how "80EF" is actually 0xEF80, but I get stuck when I get to how
    the 0x1fd00 gets encoded into the HEX equivalent.
    Can someone tell me how to figure this out?
    Charles Linquist
    GOTO is a two word instruction with the address embedded.
    With 80 EF FE F0 read from the .hex file you swap these around for
    EF 80 F0 FE.
    1st word 1110 1111 kkkk kkkk ' E F = instruction / 8 0 would be where the k's are
    2nd word 1111 kkkk kkkk kkkk ' F = instruction / 0 F E would be where the k's are
    kkkk in the above = the 20-bit address used by GOTO. The 2nd word
    address = the high 12-bits. The 1st word address = the lower 8-bits.
    0FE80 * 2 = 1FD00 which is the address to GOTO.
    Addresses in .hex files are normally 1/2 the actual value expected. To get the
    real address, multiply whatever you see in the .hex file * 2.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  2. Loop with two motor and 2 sensors
  3. Making Program Code Space your playground...
  4. Bootloader + Mainline code in single HEX file
    By dman776 in forum mel PIC BASIC Pro
    Last Post: - 19th May 2006, 23:59
  5. need hex code to make 12c509 a flip flop,
    By bruce3mn in forum General
    Last Post: - 15th November 2004, 04:23
