Setting code size boundaries
Results 1 to 11 of 11
    Sep 2005
    Campbell, CA
    Closer -
    Now I get
    Error[126]...;Argument out of range (must be greater than or equal to 2097151)
    Error[126]...;Argument out of range (__MAXROM must be used first)
    Charles Linquist
    Quote Originally Posted by Charles Linquis View Post
    And, is __MAXROM first?
    Sep 2005
    Campbell, CA
    Of course!
    Charles Linquist
    Oh Great.
    Another Mind bender.
    It seems to work on every chip except 18F8xxx
    Hmm, now what's up with that.
    Sep 2005
    Campbell, CA
    Thanks for trying!
    Charles Linquist
    You give up too easy Charles.
    Found it. Actually a documented MPASM error.
    Here's the fix. Just have to use a larger number for MAXROM.
    @  __MAXROM  0x1FFFFF
    @  __BADROM  0x1FD00 - 0x1FFFFF
    Sep 2005
    Campbell, CA
    I don't usually give up so easily - I just have a TON of code to write!
    Thanks!
    Charles Linquist
  1. 16f887 44 pin demo board code problem?
    Last Post: - 7th December 2008, 15:17
  2. Making Program Code Space your playground...
  3. code size
    By jmbanales21485 in forum mel PIC BASIC Pro
    Last Post: - 28th October 2007, 00:06
  4. Basic to Hex file Code size ratio
    By barkerben in forum General
    Last Post: - 5th January 2006, 16:37
  5. code size using On Interrupt PBP instruction
    By eduardojx in forum mel PIC BASIC Pro
    Last Post: - 21st December 2005, 10:57
