PiC12F675 w/10Mhz Xtal, any special consideration?
Results 1 to 6 of 6
    Did you defined the HS osc mode in your code?
        @ __CONFIG _HS_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON
        DEFINE OSC 8
    I don't know if IC-PROG program automatically those config fuses setting, but in their Command menu they have a Program Config (F4) option.
    Cool The good question ...
    Hi,ewand
    Did you check the clock w/ a scope ( 1/10 probe !!! ) on its output pin ???
    ... just a thought ...
  1. PIC12F675 problem with port 5
    By NL2TTL in forum mel PIC BASIC
    Last Post: - 5th June 2009, 01:23
  2. SERIN with a PIC12F675
    By ewandeur in forum Serial
    Last Post: - 30th July 2007, 15:04
  3. PIC12F675 trouble
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 18:40
