ADC problem with PIC16F917
Results 1 to 6 of 6
    Sep 2006
    Darrel,
    You are right, the code I posted did not have the comparators turned off. I had noticed that and thought that mistake was fixed. It is now, thanks for catching it.
    That unfortunetly did not correct the problem.
    VREF+ and VREF- are both now set to external pins, I have tried it with VREF- set to VDD. VREF- is set to ground. For all practical purposes the same, but it was thought using a dedicated pin for VREF- was worth a try.
    Sep 2006
    BigW,
    I realize the 2.5 is near the limit, but it is the best choice for the project. The correction factor was computed by using several samples to compute the slope of the error. Calling it an offset is bad terminology on my part.
    VSS = 5.0v
    VREF+ = 2.58v
    VREF- = gnd
    measured voltages are in the range of 0.2v to 2.0v
    Sep 2006
    Default solved
    As I said, I fully expected someone to point out a stupid mistake on my part.... and I get to be that someone. The problem was the reference itself, it was not stable.
    Thanks to everyone who took the time to look at the problem and those who made sugesstions.
    Lesson learned: check everything!
  1. ADC or ADCIN "bias" problem?
    By RussMartin in forum mel PIC BASIC Pro
    Last Post: - 26th February 2010, 19:39
  2. PIC18F2423, ADC problem
    By mistergh in forum mel PIC BASIC Pro
    Last Post: - 17th March 2009, 01:31
  3. Mutliple ADC problem with PIC16F877
    By andyto in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2007, 17:47
  4. 16F876 ADC problem
    By Douwe in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 19:38
  5. Problem reading multiple ADC ports
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 16:46
