Blink.bas Program
Results 1 to 5 of 5
    Talking Rtfm !!!
    NOooooooo,
    You didn't read your manual ... have a closer look to the TABLE in § 4.11 "PINS" ... page 26 Bottom.
    Everything explained ...
    Now, for your own sake ... much better to Write " High Portb.0 " !!!
    and FULLY use the example shown in page 6 ... of the Manual !!! not that from a STAMP example ... even if compatible.
    Feb 2007
    Talking
    Thanks for the reply. I did not look at that table because of it saying BASIC stamp.
    You are correct. That is the area to explain the reason it works.
    I will go back and read the manual again this time not skipping info on BASIC STAMPS just i ncase i run into this problem again.
    Merlin Knight
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 09:54
  2. Replies: 1
    Last Post: - 23rd May 2009, 09:22
  3. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 14:51
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 14:30
