Blink.bas Program
Results 1 to 5 of 5
    Feb 2007
    Question
    I read the manual. Here is the program, i still don't understand this with Microchip Pic 18f4520.
    loop:
    High 0 ' Turn on LED connected to PORTB.0
    Pause 500 ' Delay for .5 seconds
    Low 0 ' Turn off LED connected to PORTB.0
    Goto loop ' Go back to loop and blink LED forever
    Tell me what, in this program, states PortB pin 0. How is it configured?
    Talking Rtfm !!!
    NOooooooo,
    You didn't read your manual ... have a closer look to the TABLE in § 4.11 "PINS" ... page 26 Bottom.
    Everything explained ...
    Now, for your own sake ... much better to Write " High Portb.0 " !!!
    and FULLY use the example shown in page 6 ... of the Manual !!! not that from a STAMP example ... even if compatible.
    Feb 2007
    Talking
    Thanks for the reply. I did not look at that table because of it saying BASIC stamp.
    You are correct. That is the area to explain the reason it works.
    I will go back and read the manual again this time not skipping info on BASIC STAMPS just i ncase i run into this problem again.
    Merlin Knight
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. Replies: 1
    Last Post: - 23rd May 2009, 10:22
  3. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 15:51
  5. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 15:30
