Pic Start Plus Help
Results 1 to 5 of 5
    Dec 2004
    nebraska
    Default Pic Start Plus Help
    Hello
    Im having problems programing a Pic 18F458 chip using Pic Start Plus. I just bought the Pic Start Plus to use and I cant seem to get it running. I have been using a picQuik programmer for the last couple of years and have had no problems with it.
    here is the complete example code I tried to use just to make sure the picstart was working
    trisb = 0
    portb = 1
    I use microcode studios and PBP 2.46
    When I open the Hex file in MPLAb 7.41 and program it says that it worked and verified. But chip does nothing.
    When I program the hex code into the chip with my Picquick it works.
    I thought maybe in MPLAB I was not getting the config bits to program but it appears when you hit program it programs everything to the pic.
    If I put this Code in Microcode compile and then load hex file with MPlab it works.
    Pause 1000
    TrisB.1 = 0
    PortB.1 = 1
    Please Help
    Is there an include file that I am suppose to be using in my microcode program.
    So, is the problem with PICStart/MPLAB or with one of your posted code snippets?
    Microcode studio will automaticly include the device specific file(s) based on which device you select in the drop-down list in MCS. You can then either set the config fuses in your program (search the forum for info) or set them manually in MPLAB.
    In MPLAB: Enable the PIC-start, select the desired device and import the .hex file. Now goto Configure/Configuration bits and check that everything is as it's supposed to be, then program the chip.
    /Henrik Olsson.
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    try this
    trisb = 0
    portb = 1
    here:goto here
    so your code does not go off into no-where (I am not sure what your other programmer does with the unused space but, depending on your MPLAB settings, you may have stuff there)
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Dec 2004
    nebraska
    Thanks you guys.
    It was late last night while I was working on it and my code was supposed to be simple to make sure it was working. Problem is Portb = 1 would make portb.0 = 1 and the rest of portb 0's. Im not using portb.0. Thanks for you help though. I'll try to get more sleep before I ask another stupid question.
    <table><td>don't worry about that... it happen to everybody one day or another</td><td></td></table>
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
  3. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 21:42
  4. LINX RF module and PIC (#2)
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2006, 18:56
