How to use RSIN
Results 1 to 6 of 6
Thread: How to use RSIN
    This is PROTON PDS. As usual, the PORTA have some multiplexed analog stuff on PORTA that MUST be disable first.
    ADCON1=7
    or
    ALL_DIGITAL = TRUE
    should do the trick. Also, you should set your config fuses. something like
    REMINDERS=FALSE
    Config LVP_OFF, HS_OSC, WDT_OFF
    The right forum for you will be www.picbasic.org/forum
    Mar 2007
    Brisbane
    Smile
    Thanks for your feedback. I'll try the Proton PIC Basic Development Forum.
    But I'll also take on board your advice, thanks Steve.
    Mar 2007
    Brisbane
    Smile Problem solved
    Many thanks, Steve. ADCON1=7 did the trick!
    Good! it's just weird that it's worked even without MAX232 and in TRUE mode.. but anyways.
    enjoy!
