How to use RSIN
Results 1 to 6 of 6
Thread: How to use RSIN
    Mar 2007
    Brisbane
    Question How to use RSIN
    I'm having a lot of trouble reading serial input! Can anyone help?
    The circuit is receiving input from a computer running Hyperterminal set at 9600,N,8,1. (There's no MAX232 driver chip.) Here's the code -
    Device=16F877
    XTAL=20
    Declare SERIAL_BAUD = 9600
    Declare RSIN_PIN = PORTA.0
    Declare RSIN_MODE = 0
    Declare RSIN_TIMEOUT = 10000
    Dim Serdata As Byte
    TRISD=%00000000 'Just to prove the computer has started
    PORTD=%00000100 'turn on an LED
    Print "Waiting..."
    DelayMS 1000
    Start:
    Serdata=RSIn,{TO_ERROR}
    Print HEX Serdata, "*"
    GoTo Start
    TO_ERROR:
    Print Cls, "Timed Out"
    Stop
    The program produces the following result on power-up:
    With RSIN MODE set to 1, (which I think is right) I get "Waiting", 1 second delay, 0*0*0*0*0*.......... but never any input characters.
    With RSIN MODE set to 0, I get "Waiting", 11 second delay, "Timed Out"
    The signal on pin 2 of the 16F877 is roughly -
    +5v __ __ __
    -0.5v _______ __ __ ___________
    I have tried an 18F4550 with same result. I must be missing something important here!
    Hi Tim,
    I'd love to be able to help you but I think you are in the wrong forum. I don't know which compiler you're using but this forum is for the Micro Engineering Labs PIC Basic Compilers (Standard and PRO).
    Sorry....
    /Henrik Olsson.
    This is PROTON PDS. As usual, the PORTA have some multiplexed analog stuff on PORTA that MUST be disable first.
    ADCON1=7
    or
    ALL_DIGITAL = TRUE
    should do the trick. Also, you should set your config fuses. something like
    REMINDERS=FALSE
    Config LVP_OFF, HS_OSC, WDT_OFF
    The right forum for you will be www.picbasic.org/forum
    Mar 2007
    Brisbane
    Smile
    Thanks for your feedback. I'll try the Proton PIC Basic Development Forum.
    But I'll also take on board your advice, thanks Steve.
    Mar 2007
    Brisbane
    Smile Problem solved
    Many thanks, Steve. ADCON1=7 did the trick!
    Good! it's just weird that it's worked even without MAX232 and in TRUE mode.. but anyways.
    enjoy!
