10bits adc using 16f877
Results 1 to 8 of 8
    274 instead of 304... it's not as this far. Everything is related on acurracy of the VREF. IF it's REALLY 5.000000000V then you should have
    (1.5/5)*1024=307
    If my maths are good after 20 hours awake, ((307-274)/1024)*100=3.22 % of error. so your supply line should be around... 5-(3.22%)=4.9844 Volt
    If i use a serial communication here and if i inject 1.499 volt, VDD=5.014, i should read... (1.499/5.016)*1024=306 right? i have 305 wich is real darn close.
    If your ADC input is a little bit noisy, it may change the results, same thing with the VDD line. If you respect the minimum acquisition time and the maximum input impedance... you will have the nice results.
    If you need accuracy, you may decide to use a precision voltage source.
    mmm, maybe 1023 instead of 1024....
    thanks a lot for ur help even after 20hours awake..its realy help me..possibly its caused by the noise..im gonna check it again..thanks a lot
    Default hi
    i've check it..but the regulator input is 4.8V..is there posibbly coz by my wrong ADCON1 register?..
    thank you
    Regulator INput or OUTput?
    if it's output, the results make sense. use the previous calc i did.
    If it's INput... and if it's a simple 7805... the output signal will be pretty bad
    Jan 2007
    Thumbs up
    If you have a noise problem, try setting the settling time on the ADC to a few microseconds, then initiating a conversion. At the same time, make the PIC SLEEP for around the same length of time as the conversion. This should SIGNIFICANTLY reduce the noise across the PIC silicon substrate and give you a lot better accuracy.
  1. Stable Adc Reading Routine
    By gebillpap in forum General
    Last Post: - 13th May 2015, 03:18
  2. Can't get ADC to loop
    By TravisM in forum mel PIC BASIC
    Last Post: - 11th October 2009, 16:33
  3. Replies: 8
    Last Post: - 5th May 2009, 21:10
  4. ADC value with 2 decimals on an LCD
    Last Post: - 2nd December 2005, 16:54
  5. 12F675 ADC 'Issues'
    By harrisondp in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 02:55
