4 Chanel Dmx512 ready assembly code to PBP ?
Results 1 to 11 of 11
    Feb 2003
    Quote Originally Posted by syscoder View Post
    hi friends i search in the forum and found many examples thanks.
    You also appear to have MANY POSTS.
    Why post the same thing in three threads in the same forum ?????
    I didnt read the whole of your code but just this bit is flawed.
    level1 = RCREG
    So at this point you are reading a lighting level 00-FF (0-255) into a variable called "level1"
    portC.1 = level1 'i want to dimm led on port c.1
    Now you try to assign a byte size variable to a single BIT of an output port which can only ever be 0 or 1, OFF or ON.
    It has been stated several times that you need to create a PWM signal to DIM your LEDs. You need to read up on how to do that. Plenty of examples all over the forum and the wider Internet.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Mar 2007
    Default dmx
    i looked all of this forum and internet but couldnt find any example for that can you send where is it?
    ot if you can help maybe you can writte to me some code
    Jun 2005
    Wisconsin
    Angry
    We, the forum, aren't in the habit of writing code for people. You might be able to pay someone to write the code for you.
    Please stop posting in multiple locations about this issue
    Quote Originally Posted by DynamoBen View Post
    Yep, I'm done with this guy too...
    malc-c's Avatar
    malc-c Guest
    Syscoder, would you care to run through your code you posted and comment on what it is supposed to do at each section... my guess is that you can't because its's something you have simply copied from someone else, otherwise you would of spotted the flaw Keith has pointed out.
    You see this forum isn't a place where you come and ask for someone to provide free of charge the code and schematic for your project. Its a forum where others help you resolve problems with your own code. The guys here are very helpful, but its a two way exchange and you have to put in the effort too, and show that you have an understanding of the basics of what you are trying to do, something which you obviously haven't as you would of understood that any dimming / fading of lights generally requires a PWM output from the PIC.
    Maybe if you stopped posting about the same subject in several threads, swatted up on the fundimentals of DMX control, write your own code, breadboard the hardware and then post back here with your code when you have issues, you might get a more welcome responce.
    Quote Originally Posted by malc-c View Post
    Or maybe not!
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 09:02
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  3. Making Program Code Space your playground...
  4. Making PBP code more modular
    By forgie in forum General
  5. Replies: 2
    Last Post: - 8th August 2004, 16:00
