4 Chanel Dmx512 ready assembly code to PBP ?
Results 1 to 11 of 11
    Mar 2007
    Default 4 Chanel Dmx512 ready assembly code to PBP ?
    Hi friends i have found a dmx512 receiver code for 16f628 in another web forum and made some changes on it.
    it is 4 chanel dimming code working on 20 MHZ osc. tryed it and working no problem on it
    but i want to make same code in PBP can you help me for this ? Assembly Code is here ............
    http://members.chello.nl/g.assies/DMX2.pdf
    Quote Originally Posted by syscoder View Post
    Sure, I can help you.
    How much money do you want to spend on it?
    Or you can write some code yourself (again), and we can probably HELP you make it work, instead of make it work for you...
    malc-c's Avatar
    malc-c Guest
    Firstly, I class myself as a newbie when it comes to PBP... so can't help you out with your question.
    However, I think that you are asking a tool order if you want the guys here to convert assembly code to a working PBP program and then help you modify it and adapt it to suit your needs.
    Maybe you should / could contact the author of the assembly code and ask them if they could interpret what each line of ASM code does, and then have a go at writing the PBP code and then post that up and ask for assistance if / when it won't work.
    Mar 2007
    Default dmx
    it is ok thanks i have solved it and working now. no problem on it..
    Mar 2007
    Default dmx
    hi friends i search in the forum and found many examples thanks. i have pic 16f876 , 20 mhz osc and 1 led ,i have dmx512 lighting desk too and i want to dimm a led on dmxadres 1 (0-255 to led intensty) but there is some problem on this code it is not working. i found this code in the forum and made it again for my pic but couldnt find the problem.can you look to my code and say what is my problem here?or you can send other example code to receive dmx ..
    ' PIC 16F876 - 20MHZ OSC
    DEFINE OSC 20 ' 20 MHZ OSC
    DEFINE HSER_TXSTA 24h ' Enable transmit
    DEFINE HSER_SPBRG 4 ' 250 000 Baud @ 20MHz, 0.0%
    ERRORLEVEL -306, -302
    ADCON0 = 0
    ADCON1 = 7
    counter var word
    idleflag var word
    dummy var word
    RCIF VAR BYTE
    startcode var word
    aminus var word
    adress var word
    x var word
    level1 var word
    adress = 1 ' My Start Adress
    checkdmx:
    counter = 1 ' Dummy variable
    pulsin portC.7,0,counter 'Here looking for the break signal
    if counter = 0 then
    idleflag = 1 'either no dmx , or break was too long to count
    'return
    if counter < 40 then checkdmx ' watching for "break"
    dummy = RCREG
    dummy = RCREG
    SPBRG = 0
    TXSTA.2 = 0
    TXSTA.4 = 0
    RCSTA.7 = 1
    RCSTA.6 = 0
    RCSTA.4 = 0
    RCSTA.4 = 1
    while RCIF = 0: wend
    startcode = RCREG 'firs byte after break
    if startcode <> 0 then checkdmx
    aminus = adress -1
    for x = 1 to aminus
    dummy = RCREG
    next x
    level1 = RCREG
    portC.1 = level1 'i want to dimm led on port c.1
    RCSTA.7 = 0
    goto checkdmx
    Feb 2003
    You also appear to have MANY POSTS.
    Why post the same thing in three threads in the same forum ?????
    I didnt read the whole of your code but just this bit is flawed.
    level1 = RCREG
    So at this point you are reading a lighting level 00-FF (0-255) into a variable called "level1"
    Now you try to assign a byte size variable to a single BIT of an output port which can only ever be 0 or 1, OFF or ON.
    It has been stated several times that you need to create a PWM signal to DIM your LEDs. You need to read up on how to do that. Plenty of examples all over the forum and the wider Internet.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Mar 2007
    Default dmx
    i looked all of this forum and internet but couldnt find any example for that can you send where is it?
    ot if you can help maybe you can writte to me some code
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 10:02
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  3. Making Program Code Space your playground...
  4. Making PBP code more modular
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
  5. Replies: 2
    Last Post: - 8th August 2004, 17:00
