DMX on 250000 baud receive
Results 1 to 17 of 17
Threaded View
  1. #17
    Nov 2004
    newlevel1 = RCREG 'This is your target channel data
    portA.2 = newlevel1 'i want dimming a LED on PORTA.2
    RCSTA.7 = 0 'turn off the USART
    Just curious - how do you expect a single pin, which at any given time can only have one of two discretes states, to represent all 255 possible values of DMX channel data?
    Hint: Pulse Width Modulation is your friend. It's a way to time-average a bunch of discrete states (ones and zeros) to approximate various channel levels.
    Search for 'PWM' and see what you find. Check out 'HPWM' in your PBP manual. You'll also find many, many examples of software controlled PWM buried in this forum.
    And if you're really ambitious, google for Artistic License's 'Bit Angle Modulation' white paper. It's ingeniously simple and requires almost no work to code the routine in software.
    JEC
    EDIT: Didn't realize this same question had been replied to in two other threads in the past few hours. Sorry to repeat what everyone else has been saying re: PWM & R'ing the Friendly Manual.
  1. DMX receive issue
    By NoahLD in forum mel PIC BASIC Pro
    Last Post: - 27th August 2014, 14:51
  2. A Serial GLCD 128x64 Simple Project
    Last Post: - 8th March 2010, 21:58
  3. Big Problem in PBP To receive DMX
    By programmer07 in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 19:49
  4. Auto Baud Rate Detection
    By mytekcontrols in forum Serial
    Last Post: - 31st October 2005, 03:17
  5. Baud Rate and Timing Calculator
    By picnaut in forum General
    Last Post: - 23rd January 2004, 17:48
