programmer
Results 1 to 4 of 4
Thread: programmer
    Cool programmer
    i am presently using pbp and mcs+ there is a couple of issues when i try to use the icd and bootloader on some programs timing issues i guess
    what i am looking for is another programer that would allow in circuit programing and debuging and not require the boot loader
    lookedat several but not sure what to get
    would be nice if it was designed to work with what i am presently using
    My suggestion would be the MicroChip ICD-2, which run under MPLAB. Of course there's a few clone of it here and there... can't comments on them.
    PICKIT 2 is fine, but for now, its ICD is way to limited.
    what kind of issues do you have? which crystal speed are you using? (usually 20MHZ works better)
    any code example of something you have problem with?
    Default kiss
    sorry mister e did not explain myself well
    looking for something simple mplab is totalally out of my ability
    any otherm suggestions perhaps from someone who also has limited knowledge that has tried this
    thanks
    kiss keep it simple stupid
    Yeah KISS engineering... i like that
    But you didn't answer my previous questions
    Anyways, a serial communication, a LCD do the job as well and don't require any Bootloader (even if pretty handy) or ICD. Nobody work the same way. I don't use ICD really often. few times a year or so.
    Any ICD will be slow, so you may need to enclose some part of your code with ENABLE DEBUG and DISABLE DEBUG.
  1. Melabs U2 Programmer Command Line Options
    By Robert Wells in forum General
    Last Post: - 3rd July 2009, 02:11
  2. problems with USB programmer
    By malc-c in forum General
    Last Post: - 10th May 2007, 20:14
  3. USB programmer problems
    By uiucee2003 in forum USB
    Last Post: - 15th August 2006, 23:47
  4. Melabs USB Programmer
    By tmurph in forum General
    Last Post: - 25th December 2005, 03:25
  5. General Programmer Questions
    By mslaney in forum General
    Last Post: - 17th December 2004, 18:16
