first let me say that my programs run and assemble fine
however when i try to set fuses using mpsam i get a couple of errors
this does not happen when i set fuses using pbp
but its frustrating read a bunch of posts on this subject must not be alone
can someone give a dinfintive answer on mpsam fuse setting not pbp
the command line is ok but get the errors anyway pbp assembles faster
guess if cant get answer just use this
</td><td>it always help us when you provide the exact error message(s).
</td><td>
