Input / output using same pin
Results 1 to 3 of 3
    Feb 2005
    Portugal
    Default Input / output using same pin
    I'm thinking to use the same PIC I/O to drive a led and to be an input from a switch, this is being an input/output just by changing TRIS. It's possible isnīt it? I'm using the circuit attatched
    Yes that would work. The drawback is that the LED will be ON while you push the button.
    /Henrik Olsson.
    You don't actually need R1 as R2 via the LED will pull the pin high during the input mode, and all it will do is add extra unnescessary load to the I/O pin during output mode..
  1. Microcontroller with 2 way paging application problem
  2. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  3. Serious Serial Situation Setbacks...
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. WPU - Input - Output pin triangle
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 1st July 2006, 12:43
