LM35DZ + Temp
Results 1 to 14 of 14
Thread: LM35DZ + Temp
    Jun 2006
    ' **Setting for ADC of 16F88**
    Define ADC_BITS 10 ' 10-bit ADC used
    Define ADC_CLOCK 3 ' Internal clock used
    Define ADC_SAMPLEUS 50 ' Sample timing
    Samples var word:Sample var byte:Vin var Word:Samples=0
    ADCloop:
    For Sample=1 to 10:ADCIN 2,Vin:Samples=Samples + Vin:Pause 200 Next sample
    Vin=Samples/10:Vin=(Vin*/500)>>2:Lcdout $fe, 1:LCDOUT $FE,2
    Lcdout "Temp=",DEC (Vin DIG 2),DEC (Vin DIG 1),".",DEC (Vin dig 0),"C"
    Samples=0:goto ADCLoop
    It's not show corect.
    I try the code below and work but the decimal change every 0.5C
    How change to have resolution every 0.1C
    	Quanta		Con	1250
        ADCIN 2,AD_Result			' Place the conversion of channel0 into AD_RESULT
    	Volts = (AD_RESULT*10) */ Quanta
    	Lcdout $FE,1
        Lcdout "Temp : ",dec1 Volts DIG 3,DEC1 Volts DIG 2,".",DEC1 Volts DIG 1,DEC1 Volts DIG 0,"C"
                                    ' So as to display like "23.4C"
    Quote Originally Posted by savnik View Post
    Ok, forget all the math and displaying for the moment...
    What is the output on the LCD if you only read the A/D converter with the LM35DZ connected... no averaging, no multiple samples, no nothing, just one saple, one display...pause, one sample, one display, and so on...
    Get a good reading that seems to make sense, then we can work on displaying it correctly...
    Jun 2006
    The output on the LCD is 44-46 (Vin = 44~46)
    The temperature is about 22C in room
    Jun 2006
    I change to :
    ADCloop:
        ADCIN 2,Vin
        Pause 200
        Vin=(Vin* 10)/2
        Lcdout $fe, 1
        LCDOUT $FE,2
        goto ADCLoop
    and believe is right
    The LCD now show : Temp=22.5C
    The LM35 puts out 10mv/°C.
    1 "Step" of 10-bit A/D is 4.88mv.
    So each "step" equals ~0.5°C
    If you use a Vref of 2.5V, you could get 0.25°C resolution.
    With an op-amp you might get down to 0.1°C res. if you don't need the full +150°C range.
    Or you could use a DS18B20. That'll get 0.0625°C.
    Good call DT! I thought the datasheet said 1mv/C.
    Jun 2006
    Thank you for answer
    I have use this schematic
    Jun 2006
    I want to measure from 0 - 100C
    So what's the problem? The answer has already been given to you twice in the posts above, even if other parts of the code were wrong, if you'd take a few seconds to look over the display part of the above code, you'd find your answer, between that and the PBP manual, which does describe what you need...
    Jun 2006
    I answer , don't ask
    what happened in your first example?
    If you used DEC3, what was the results...apart that the decimal point was missing?
    Now, i have set ADCON1 register to produce Right Justified results (ADCON1.7=1) and used this
    ADCloop:
        For Sample=1 to 10          ' Take 10 samples
            ADCIN 0, Vin                ' Read ADC ch-2 and save in Vin
                                        ' (range 0-1023)
            Next sample
        Vin=Samples/10              ' Mean of 10 Vin values
        Vin=(Vin*/500)>>2
        Lcdout $fe, 1               ' Clear LCD
        LCDOUT $FE,2
        Lcdout "Temp=",DEC Vin DIG 2, DEC Vin DIG 1,".", DEC1 VIN,"C"
        Samples=0
        PAUSE 100
        goto ADCLoop
    it worked.
    EDIT: ARGH!
    Jun 2006
    ADCloop:
                                        ' (range 0-1023)
            Next sample
        Vin=(Vin*/500)>>2
        LCDOUT $FE,2
        Samples=0
        PAUSE 100
        goto ADCLoop
    it worked.
    EDIT: ARGH!
    The LCD show Temp=02.5C
    but the right is Temp=25C
  1. Graphic LCD with PICbasic pro
    By amindzo in forum mel PIC BASIC Pro
    Last Post: - 25th November 2012, 12:45
  2. Stuck with 85C temp on ds18b20
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2009, 20:50
  3. Random Numbers
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 18th December 2008, 09:47
  4. help with write command
    By cphillips82 in forum General
    Last Post: - 21st April 2008, 00:49
  5. LM35DZ and 18F2455 settings
    By Mark J in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 09:31
