16F628a to 16F873a
Results 1 to 5 of 5
    Sep 2006
    Venezuela - Caracas
    yes, ADCON1 = 7
    if i test simple code serin, serout work 100%,
    with my code i receive wrong caracters,
    in 16f628 work perfect
    mmm, what happen if you do a simple test and use DEBUG instead of SEROUT. As you're using a 4MHZ clock, SEROUT may work or not.
    to me the built-in USART is always a better choice so far. and @4mhz, you'll end up with a nice error % -> 0.16%
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ 4MHz, 0.16%
    The main problem is that you'll have to change a little bit your actual setup... but...
    EDIT:
    Data_Entrada      var   PORTC.1     '1
    Data_Saida        var   PORTC.1     '1
    Should they be on a different pin?
    Sep 2006
    Venezuela - Caracas
    my code is for TRW-24G
    Data_Entrada and Data_Saida is the same pin because TRW-24G use data and clock to send data
    shiftout Data_Entrada, Clock, MSBFIRST, [Dados_Enviados[i]\8]
    shiftout Data_Saida, Clock, MSBFIRST, [Dados_Enviados[i]\8]
  1. boot loader for 16f628a ?
    By tdavis80 in forum mel PIC BASIC Pro
    Last Post: - 5th January 2008, 02:07
  2. Are 16f628 and 16f628A difference each other?
    By elektrodam in forum mel PIC BASIC Pro
    Last Post: - 15th July 2006, 06:20
  3. MPLAB ICD ver 1 & 16F628A
    Last Post: - 26th February 2005, 00:44
  4. new user with problem using PGP Pro, Lab-X3 with 16F628A
    By equipoise in forum mel PIC BASIC Pro
    Last Post: - 28th July 2004, 07:42
  5. HSEROUT and 16F628A
    By fredblah in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 00:07
