PicKit1
Results 1 to 5 of 5
Thread: PicKit1
    Mar 2007
    Default PicKit1
    Hi, I seriously need some help, I have given up trying to learn assembler and now trying picbasic but...
    I have a PICkit1 flash starter kit, and am using PBP. All I am trying to do is flash any of the eight LED's on. I have copied a program from the manual and tried to adapt it but it just isn't working. I have ran the sample program to test the chip, so I know it is not broken.
    DEVICE = 12F675
    XTAL = 4
    TRISa = %11001111
    loop: High porta.4
    low porta.5
    Pause 500
    Low porta.4
    high porta.5
    Pause 500
    Goto loop
    I am obviously lame at this but if anyone can get me started I would be really appreciative.
    Matt
    1. and nope you're not using PBP, it's PDS proton
    2. this device have no PORTa
      This device have some multiplexed stuff on almost all pin which have to be disabled first (ADCs and analog comparator)
    3. you have to set the configuration fuses somewhere in your code. if my memory serves me well, PicKit 1 don't allow to change them on the fly.
    now try
    Device = 12F675
        '        Device programming mode and hardware definition
                 ' Using Internal Clock, no clock out
                 ' Disable Watch dog timer
                 ' Disable MCLR pin
                 ' Enable Power-up timer
                 ' Enable Brown-out detect
    Config INTRC_OSC_NOCLKOUT,_
           WDT_OFF,_
           MCLRE_OFF,_
           PWRTE_ON,_
           BODEN_ON
    TRISIO = 0
    CMCON=7	        ' Disable analog comparator
    ANSEL=0	        ' Disable analog converter
    Start:
          High GPIO.5
          High GPIO.4
          DelayMS 500
          Low GPIO.4
          Low GPIO.5
          DelayMS 500
          GoTo Start
    The right forum for you will be
    www.picbasic.org/forum
    Mar 2007
    Default Thats it!
    Thank you, that does it!
    Mar 2007
    Default at last
    Thanks for your time, it has taken so long to even get a blinking LED to flash.
    I will try the other forum. At least I can use this as a template to experiment with now.
    MattK
    malc-c's Avatar
    malc-c Guest
    The other thing to watch with the PicKIT1 is the way the 8 LEDs are wired to the evaluation socket, so sometimes you expect just one LED to light and you find two light.
  1. 12f675_fuse_about_to_blow!
    By LEDave in forum Off Topic
    Last Post: - 22nd May 2011, 00:00
