18f4520 lcd problem
Results 1 to 5 of 5
    Feb 2007
    Unhappy 18f4520 lcd problem
    Hello, i am a newbie on this and was working on the 18f452. It was going great. I installed an 18f4520 to replace the 18f452 and now the lcd does not work.
    Any help would greatly be appreciated. Can't figure out why.
    I am not using the pro version . On order.
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 3
    DEFINE LCD_EREG PORTA
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_RWREG PORTA
    DEFINE LCD_RWBIT 2
    ADCON1=$07
    TRISA = $00
    TRISD = $00
    PORTA.2 = 0
    PAUSE 500
    LOOP:
    LCDOUT $FE, 1
    PAUSE 1000
    LCDOUT $FE, $0F
    PAUSE 1000
    LCDOUT $FE, $80,"Hello "
    PAUSE 5000
    LCDOUT $fe, $c0,""
    PAUSE 5000
    GOTO LOOP
    PDF datasheet, page 226, section 19-2 , ADCON1 register
    ADCON1=$0F
    Feb 2007
    GREAT! Thank you very much. I kept looking but did not find this.
    I don't understand why its causing the problem though. Looks like none of the pins are analog capable. Using pins RDO - RD6 for LCd display.
    THANKS AGAIN.
    Merlin Knight
    Quote Originally Posted by merlinknight View Post
    THANKS AGAIN.
    Merlin Knight
    None of the Port D pins are analog capable, but the Port A pins (your LCD control) are...
    Have another look at the datasheet...
    Feb 2007
    Talking
    You are correct. My bad. Thanks again for the help.
    Merlin Knight
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 09:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. Need help with LCD number display.
