TEA Encryption
Results 1 to 12 of 12
Thread: TEA Encryption
    Dec 2003
    Wichita KS
    Hello Rastan,
    Rastan, in c/c++ I use a encryption code as a word. In Assembly (or with Micochips) it lacks the ability do do such, except without high overhead and usage of memory.
    One of the oldest tricks in the book, is substitute a letter for a letter (just like a cryptocrypt in the newspaper. If you can give the reader the code to decipher it, then it is easy to "crack".
    Now, lets make this one step easier yet...99.9999 percent of all code crackers give up pretty easily. If you get that .00001 percent person, you are just out of luck. (That is why they have EUA that say you cannot "reverse engineer" etc etc etc). (Who would want to reverse Engineer a 100 meg program?) Though I have to admit, I spent 2 months reverse engineering a program and cracking it, because it used a lazer spot on a disk for its security. The company wanted BIG bucks for a upgrade, and all I wanted to do, was to get our companies data off of their file structure into "FAT"/"DOS" TEXT format, to do our own programming and Information Technology. The week I finally got our info off their "format", was the week we trashed their thousands of dollars of programs, their thousands of dollar upgrades, and said "Good Bye". the system was called NIAWKA. I think they are still in business too. They had software that took the old WANG 2200 systems, created a special "Platter" on FAT disks, and made IBM machines think they are WANG 2200 machines. It worked very well. But I wanted to be fully DOS/FAT without anyones "imulator"
    Now with that said, to do a cheapy for the spoof of the 99.9999 people...
    two ways how you can do it.
    1.
    a=g
    b=f
    c=j
    d=d
    doing it this way, you will need a table with 255 table for a lookup. and you need to pass that table to the reader, to "reverse engineer" and make sense out of it.
    The other way, is to add a certain "number" to your table... Lets say we pick the number "5"
    1=1+5=6
    2=7
    3=8
    251=0
    252=1
    255=5
    (notice when you went above 255, it started back to zero. Sine the highest number the variable can read is 255, it automatically rolls over for you! To "reverse engineer" it you just subtract 5.
    "Hello World" with just "1" added to the hex value looks like this:
    Ifmmp#Xpsme
    For most people, that looks like garbage...At worse case senario, they will find the code in 254 tries
    the code would like something like this:
    Sentence ="Hello World"
    code number var 1
    for counter=1 to sentencelength.
    Sentence[counter]=sentence[counter]+1;
    next counter
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    rastan's Avatar
    rastan Guest
    ok good idea dwayne. ill give it a go.
    thanks,
    phil
    Dec 2003
    Wichita KS
    Hello Rastan,
    One other thing...(explaining the code word);
    IN these pic chips, you pass a number (my last example uses the value 1).
    Sometimes you may want to pass a code word.
    What you can do, is a kind of CRC on that word, and pass THAT number.
    Example:
    CodeWord ="SecretWord"
    PassingValue var byte;
    PassingValue=0;
    For counter=1 to CodeWordLength
    PassingValue=PassingValue+CodeWord[counter]
    Next counter
    What this does, is add up each individual character in CodeWord.
    if it goes above 255, it automatically rolls over to zero and starts over
    again. When you get done adding up your characters out of your SecretWord, you will have a number (CRC) between 0 and 255.
    Another (more complicated to some degree, but just as easy), is to
    switch the hex numbers around...
    $48 = $84
    $12 = $21
    But passing a number insures 254 different possible codes.
    Dwayne
    Ability to Fly:
  1. encryption ?
    By RAYMON in forum mel PIC BASIC Pro
    Last Post: - 25th February 2009, 15:25
  2. xtea encryption
    By toalan in forum Off Topic
    Last Post: - 2nd May 2008, 22:13
  3. AES Encryption on PIC16F/18F
    By Emerson in forum mel PIC BASIC Pro
    Last Post: - 17th November 2005, 01:45
  4. Encryption in pics - why?
    By rastan in forum mel PIC BASIC Pro
    Last Post: - 28th February 2005, 16:23
  5. TEA encryption and embedding in PBP
    Last Post: - 19th February 2005, 02:38
