USB CDC Communications for Dummies!
Results 1 to 40 of 105
    yes the above error was me stupidly not showing windows device mangler where the right .inf file was, my bad...
    But..
    I am now doing a ' USBIN endpoint, buffer, count, nodatatloop ' every second or so, problem is when I send data to it, I only get it one byte at a time, so reading 'cat' takes 3 seconds......
    count variable is always 1 if data present, so i get 1 three times then it returns to zero
    surely I should get all 3 bytes into my buffer and a value returned of 3 for count.
    I dont lose any chars from my text string in the terminal, i think it buffers and does some form of flow control, but when i copy a text file in a dos/command window, i do lose them, i get a count of one for the first 'C' but then a zero as 'at' have got lost before i got a chance to read them.
    Ok cant edit the above but it goes like this, if i send 'cat' with hyperterminal or putty i get 3 individual chars at the pic end so need to read 3 times, if i send it from a program written in vb6, i get a 'cat' in one loop/poll etc and a bytecount length of 3, as expected, hope no one else falls foul of this.
    For anyone using this with WIN7 64 bit here is the *.inf driver file.
    Remove the .txt
  1. Simple USB Comms Problem
    Last Post: - 6th January 2010, 20:17
  2. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 00:04
  3. USB CDC help..
    By jchandir in forum USB
    Last Post: - 22nd November 2008, 21:23
  4. Replies: 4
    Last Post: - 5th November 2008, 16:21
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
