Thank you Darrel. Here are the configs from the code arnie posted earlier, which is very similar to the configs (except I used a 12 MHz oscillator) that I created earlier according to the data sheet and include file review.
asm
CONFIG_REQ
CONFIG1L = _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
; ; ; USB clock source comes from the 96 MHz PLL divided by 2
; ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2] Determines cpu speed
; No prescale (4 MHz oscillator input drives PLL directly)
CONFIG1H = _FOSC_XTPLL_XT_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
; ; ; Oscillator Switchover mode disabled
; ; Fail-Safe Clock Monitor disabled
; XT oscillator, PLL enabled, XT used by USB
CONFIG2L = _PWRT_ON_2L & _BOR_ON_2L & _BORV_2_2L & _VREGEN_ON_2L
CONFIG2H = _WDT_OFF_2H
CONFIG3H = _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
CONFIG4L = _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
; Removed ICPRT_OFF_4L used with 18F4550
endasm
Did not have the define statement included though.... try that and see soon.
Also, noticed that your oscillator settings were HS instead of XT.
--Kirt
