USB CDC Communications for Dummies! - Page 3
Page 3 of 3 FirstFirst 123
Results 81 to 105 of 105
  1. #81
    Aug 2010
    Maryland, USA
    Default Re: USB CDC Communications for Dummies!
    I ment post 54!
    Sorry for the confusion
    -Bert
  2. #82
    Back to your question about speed....
    I think it runs at USB speeds....
    Universal Serial Bus Features:
    • USB V2.0 Compliant
    • Low Speed (1.5 Mb/s) and Full Speed (12 Mb/s)
  3. #83
    Just tech notes about USB speeds:
    The original USB 1.0 specification, which was introduced in January 1996, defined data transfer rates of 1.5 Mbit/s "Low Speed" and 12 Mbit/s "Full Speed". The first widely used version of USB was 1.1, which was released in September 1998. The 12 Mbit/s data rate was intended for higher-speed devices such as disk drives, and the lower 1.5 Mbit/s rate for low data rate devices such as joysticks.
    The USB 2.0 specification was released in April 2000 and was standardized by the USB Implementers Forum (USB-IF) at the end of 2001. Hewlett-Packard, Intel, Lucent Technologies (now Alcatel-Lucent), NEC and Philips jointly led the initiative to develop a higher data transfer rate, with the resulting specification achieving 480 Mbit/s, a fortyfold increase over the original USB 1.1 specification.
    The USB 3.0 specification was published on 12 November 2008. Its main goals were to increase the data transfer rate (up to 5Gbps), to decrease power consumption, to increase power output, and to be backwards-compatible with USB 2.0. USB 3.0 includes a new, higher speed bus called SuperSpeed in parallel with the USB 2.0 bus. For this reason, the new version is also called SuperSpeed. The first USB 3.0 equipped devices were presented in January 2010.
    http://en.wikipedia.org/wiki/Universal_Serial_Bus
  4. #84
    Dec 2005
    I don't know whether I'm too dumb or not dumb enough to grasp all the intricacies of CDC but, if I understand it, there are virtual serial port drivers for interfacing on the PC side. When these are used, there's likely to be a slight speed hit as the data needs to be 'translated' from its RS232-ish form before transmitting and the reverse is true when receiving.
    This may not be noticed for normal communications but can be readily apparent when doing something like a firmware download which usuall includes short bits of data and CRC which is ACKed or NAKed from the embedded device. Of course, the faster the version of USB, the less this is a big factor.
  5. #85
    For CDC, baudrate is a meaningless parameter. You can set hyperterminal/vbSerialPort a whatsoever baudrate, the usb engine will emulate a serial communication as fast as it can
  6. #86
    Dec 2005
    I'm not talking about transmission speed and I agree that baudrate has little meaning in this context. However, I have had a lot of experience downloading firmware files which might be as big as 64KB and there is a very noticeable difference between sending them via Serial->USB->Serial vs. sending them Serial->Serial with the latter being much faster as a result of the translation that must occur (on both ends). CDC should only need to translate on the PC end but I suspect there will be a significant speed hit never-the-less on certain applications.
  7. #87
    True that. CDC is really handy for older software unable to deal with USB, somehow easier to program on both side... but to me, IN 20XX... it still sucks.
    I know your arguments... but ...Pure USB for me... all the way.
  8. #88
    Aug 2010
    Maryland, USA
    Steve, when do we get the pure USB for dummies? Both ends, PiC and PC??
    -Bert
  9. #89
    USBDemo was a kickstart for many. Time changed, PBP work tad different now, mcHID.dll/MCSP/EasyHid = somehow a dead duck, VB6 is a long time outdated thing, seems Jan Axelson code examples are not for everyone... so yeah I think it's about time.
    I know how, I know something rock solid. Keyword: be patient...
    (Still, there's LOAD of ressource/ready to go components/lib over the net on the PC side)
  10. #90
    Aug 2010
    Maryland, USA
    and I quote:
    AAwwww come on guy, don't be lazy
    After spending my weekend searching and reading. I have come to the conclusion there is in fact - tons of examples and ready stuff all over the net. But does this help if one doesn't know where to start? Even bought Jan's book to help me. And it did. Now I assume my weekends work would amount to 30 minuites for someone able to write a picmulticalc. So a quick VB express (cuz it free to all) example passing a byte or 2 back and forth. Nothing more then that as it will overwhelm those who don't get it. ( read as ME ME ME)
    -Bert
  11. #91
    Dec 2005
    Ahh, you mean like waiting for the long-promised Tibbo EM500/GA1000 firmware. I'm down with that.
  12. #92
    Everyone must start somewhere. Been there done that. I'm not more clever than anybody, but maybe I put more time & effort. I never found a magic potion to know everything and how to do things in a snap.
    1) have a project
    2) find information, read, digest them
    3) try something
    4) wash & rinse 'till it works
    You CAN'T learn VB (or else) in a day. It take months, years. I learnt the hard way too. The more you do, the more you develop tricks....the easier it gets.
    Don't give up!
  13. #93
    OH Really? Weird, It's the really first time I hear you about this long-promised Tibbo EM500/GA1000 firmware.
    Ham Mucus
  14. #94
    Dec 2005
    Yeah - I've probably made my point so I guess I'll go back to patiently waiting in silence.
  15. #95
    Humanity have been created in 7 days (or so) ... this ought to be a huge firmware
  16. #96
    Aug 2010
    Maryland, USA
    Don't give up!
    NEVER!!
    I learned ASM with nothing more then the datasheet for my chip I wanted to use. So I won't give up. But its nice to have people to ask for help. No, I don't profess to even come close to knowing all there is to know about ASM, but I can get by.
    -Bert
  17. #97
    Keep it for yourself, I'll share a secret with you... I'm a forum addicted guy They are golden opportunities to learn faster... grab someone's problem, work on, find a solution... then someone else post an alternative, observe, wash & rinse.
    Again... keep it for yourself
  18. #98
    Apr 2013
    Hi guys,
    can you help me with program USB CDC Communicator on uC PIC18F47J53?
    I never use USB, this is my first try.
    I tried use the sample code from USB18 (CDC_demo). I tried rewrite the code but without success.
    Thx.
  19. #99
    Apr 2013
    Proglem solved:
    Must use #congif for PIC.
    ' USB sample program for PIC18F47J53 CDC serial port emulation
    ' Requires PBP 2.60 or later
    Include "cdc_desc.bas" ' Include the HID descriptors
    Define OSC 48
    CONFIG WDTEN = OFF ;WDT disabled (enabled by SWDTEN bit)
    CONFIG PLLDIV = 3 ;Divide by 3 (12 MHz oscillator input)
    CONFIG STVREN = ON ;stack overflow/underflow reset enabled
    CONFIG XINST = OFF ;Extended instruction set disabled
    CONFIG CPUDIV = OSC1 ;No CPU system clock divide
    CONFIG CP0 = OFF ;Program memory is not code-protected
    CONFIG OSC = HSPLL ;HS oscillator, PLL enabled, HSPLL used by USB
    CONFIG FCMEN = OFF ;Fail-Safe Clock Monitor disabled
    CONFIG IESO = OFF ;Two-Speed Start-up disabled
    CONFIG WDTPS = 32768 ;1:32768
    CONFIG DSWDTOSC = INTOSCREF ;DSWDT uses INTOSC/INTRC as clock
    CONFIG RTCOSC = T1OSCREF ;RTCC uses T1OSC/T1CKI as clock
    CONFIG DSBOREN = OFF ;Zero-Power BOR disabled in Deep Sleep
    CONFIG DSWDTEN = OFF ;Disabled
    CONFIG DSWDTPS = 8192 ;1:8,192 (8.5 seconds)
    CONFIG IOL1WAY = OFF ;IOLOCK bit can be set and cleared
    CONFIG MSSP7B_EN = MSK7 ;7 Bit address masking
    CONFIG WPFP = PAGE_1 ;Write Protect Program Flash Page 0
    CONFIG WPEND = PAGE_0 ;Start protection at page 0
    CONFIG WPCFG = OFF ;Write/Erase last page protect Disabled
    CONFIG WPDIS = OFF ;WPFP[5:0], WPEND, and WPCFG bits ignored
    buffer Var Byte[16]
    cnt Var Byte
    OSCTUNE.6 = 1 ' Enable PLL for 18F47J50 family
    Pause 10
    USBInit ' Get USB going
    '* Set PORTA, PORTB, PORTC, PORTD PORTE to input/output *
    TRISA = %00100010 ' Set PORTA to output
    TRISB = %00001000 ' Set PORTB to output
    TRISC = %00---000 ' Set PORTC to output
    PortA = %00000000 ' Set PORTA to 0
    PortB = %00000000 ' Set PORTB to 0
    PortC = %00000000 ' Set PORTC to 0
    PortD = %00000000 ' Set PORTD to 0
    PortE = %00000000 ' Set PORTE to 0
    '* SET LCD *
    Define LCD_DREG PORTD
    Define LCD_DBIT 4
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 0
    Define LCD_EREG PORTB
    Define LCD_EBIT 1
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 1500
    DEFINE LCD_DATAUS 50
    Pause 1000 ' Wait for LCD to start up
    '* LOOP *
    ' Wait for USB input
    idleloop:
    USBService ' Must service USB regularly
    cnt = 16 ' Specify input buffer size
    USBIn 3, buffer, cnt, idleloop
    ' Message received
    buffer[0] = "O"
    buffer[1] = "K"
    buffer[2] = 13
    buffer[3] = 10
    buffer[4] = 0
    outloop:
    USBOut 3, buffer, 5, outloop
    Goto idleloop ' Wait for next buffer
  20. #100
    Jun 2011
    Philippines
    Hi.. I have windows 7 64bit machine... I download the 64_mchpcdc.inf provided by mackrackit...and copy and paste it in the Windows\sysWOW64 folder, I also reboot the machine but I'm getting exclamation icon(CDC - R232 Emulation Demo) in the devices and printers window. What do you think I'm doing bad? Please give advice.
    Thanks in advance,
    tacbanon
  21. #101
    The driver provided with PBP now has 64 bit support added. So you do not need the one I linked to, although it should still work.
    I think your problem might be that you copied it to a directory rather than letting the OS install it. Try deleting the file from the sysWOW directory, then do a reboot.
    When your project is plugged into your PC windows should bring up the usual dialog asking to install a driver. Do not let windows look for it, point to where the file has been saved to and let windows do the installing. You then should see a virtual com-port in device manager.
  22. #102
    Jun 2011
    Philippines
    Hello macrackit, thank you so much for replying...I got it working now.
  23. #103
    Jun 2008
    Varese , Italy
    Good day,
    I have PBP 250_b running on a windows_7 64 bit.
    What files are required in my PBP to update it to the 2.60 version and use the USB programs ?
    Where could I download them ?
    Thanks for helping
    Ambrogio
  24. #104
    You will have to go to MeLabs website and pay for the upgrade.
  25. #105
    Hi Steve. Any news about this promised demo?
  1. Simple USB Comms Problem
    By awmt102 in forum mel PIC BASIC Pro
    Last Post: - 6th January 2010, 20:17
  2. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 00:04
  3. USB CDC help..
    By jchandir in forum USB
    Last Post: - 22nd November 2008, 21:23
  4. Replies: 4
    Last Post: - 5th November 2008, 16:21
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
