In your original post you asked if anyone has used DT's files in a program and experienced any problems. Well I have used it recently (see the model train controller thread below) and can report that it works fine.
Yes I had to tweek my code, and we played about with the values, and a couple of things were overlooked in the examples, but I received excellent support from DT and Steve (aka mister_e) as can be seen if you follow the thread.
You got off to a bad start by jumping in all guns blazing shooting down DT's code, so in some respect you deserved the reply you got at the start of the thread. However I'm sure if you post your code here, the problem will be resolved with Steves and Darrels help and you both can get along without throwing your teddy's in the corner![]()
