Timing input pulses and re-outputting them
Results 1 to 6 of 6
    Quote Originally Posted by jamie_s View Post
    Where im stuck is how to create the output pulses and perform the checks on the input pulses without missing any of the input pulses. Also on how to keep the output pulses happening whilst there is no input.
    I have a feeling that the pulsout and pauses will hang the program thus missing the next input pulse in the sequence while it is completing the operation of sending the output pulse?
    Anyone have any ideas / comments on this, im sorry if the post above is a bit full on and confusing but i had to type it all while it was fresh in my head
    Check your PBP manual, pages 118 and 204, to handle the pulsin waiting problem.
    Aug 2005
    PULSIN is not my issue, i need help with the output
    Oh, misread you a bit. How about this:
    Instead of concentrating on timing and monitoring the input with the hardware, why not set up a 50% duty cycle PWM signal on an output, running continuously at 16hz, not needing any help from the program, all driven by the hardware.
    Use the program (pulsin) to monitor the input and change the PWM registers to match the input once it gets above 16hz. Set the pulsin_max to a pulse width corresponding to 16hz at your oscillator speed (ie. OSC is 4mhz, pulsin_max value is 10us per count, pulsin_max = 6250).
    With the PWM module, you can change freq and duty cycle, all you have to do is the math for it and change the registers to suit your needs.
    Or am I still out in left field for what you're wanting...
    Aug 2005
    I was looking at PWM, but dont beleive it will go as low as 16hz?
    Well, if you use a PIC that has a programmable clock source (a lot of the newer ones do), you could change that clock 'on-the-fly' to get it down to 16hz, or do it thru TMR interrupts until the freq gets up to a point where you can use the PWM. For one thing, I don't know which PIC you're going to use ! Also, 16hz is the minimum freq, what's the max?
