IDE with emulation!
Results 1 to 23 of 23
    Italy
    Far as I'm aware, VB doesn't cater for true OOP - Object Orientated Programming. There's no Polymorphism, inheritance, yada, yada, yada. It is object-based though. Not so long ago I used to confuse myself with the two. There's a lot of debate about what VB can and can't do.
    Hi Trent,
    Did you ever try with VB6?
    Programming with Objects (MSDN Library / VB6)
    http://msdn.microsoft.com/library/de...ithobjects.asp
    Programming with Your Own Objects (MSDN Library / VB6)
    http://msdn.microsoft.com/library/de...ownobjects.asp
    If not, then use C# or VB.Net. (Good investment for the future).
    Object-oriented programming is almost ineluctable if you want to
    develop your own simulation programs.
    Best regards,
    Luciano
    T.Jackson's Avatar
    T.Jackson Guest
    Post Done a lot of object-based programming.
    Hi Luciano,
    Yes, over the years I have done a lot of object-based programming in VB.
    I agree, Object-Orientated-Programming would be an essential ingredient to be used with any complex simulator such as Proteus.
    No plans on anything like that for a while. I'm currently a full time student with nothing but a lot of discrete maths and technical jargon on my mind.
    Best Regards,
    Trent Jackson
    Jul 2005
    I would love to see a "simulator" included in PBP / Microcode studio.
    as a hobbyist my usual design strategy is:
    a) concept diagram
    b) breadboard
    c) wirewrap version
    d) homemade photoresist (the kind you expose to light with your design overtop) etched pcb
    Sep 2007
    USA, CA
    Quote Originally Posted by RYTECH View Post
    a) concept diagram
    b) breadboard
    c) wirewrap version
    Check out the VSM at www.labcenter.co.uk --it will run full spice on most PIC's. It will only run PBP compiled into ASM code.
    If you want to run it step by step in Basic, the Proton+ compiler comes with a limited version of the VSM that has a handful of fixed (not editable) development boards. This allows you to test most of your code, unless it is totally hardware dependent. Combining the VSM and Proton allows you to edit the hardware and step through the basic code...this gets expensive, but is worth it if you code a lot.
  1. Replies: 0
    Last Post: - 13th February 2009, 04:34
  2. IDE FineLine Viewer
    By Normnet in forum PBP Extensions
    Last Post: - 23rd August 2008, 04:15
  3. Upgraded to MPLAB IDE 8.14 and now I'm stuck
    By BlueHairBob in forum General
    Last Post: - 20th August 2008, 02:15
  4. FineLine IDE for PicBasicPro
    By Normnet in forum PBP Wish List
    Last Post: - 9th September 2007, 23:59
  5. To IDE or Not to IDE
    By Melanie in forum General
    Last Post: - 3rd March 2007, 00:30
