microns to decimal conversion
Results 1 to 5 of 5
    Jan 2007
    Default microns to decimal conversion
    Micron to Decimal Conversion
    I am using an 18F4431(and a 18F4550) with encoder inputs.
    The development board is a LAB-XUSB.
    The scale being used is in microns.
    1 count = .0003937 inches.
    I do not need the resolution the
    encoder and scale provide but I need to
    use this encoder and scale.
    I will need to convert microns to
    decimal for data logging.
    I will need to perform a calculation
    To see if the value falls outside of a
    plus(+) or minus(-) point.
    Example
    .000 is the datum.
    The deviation allowed is
    + or - .010. Therefore, if
    the reading is .013 then the
    unit has failed and I would
    report this to the user.
    I have tried using integers with no
    success. I have not attempted
    floating-point math. I do not
    know how to incorporate the
    routine into Pic Basis Pro at present.
    I do not know which routines
    of the samples provided to incorporate.
    I am still studying a method to implement.
    I need to be pointed in the right direction.
    Any help will be appreciated.
    Thank You.
    Richard
    Default Integer math
    Hello Richard,
    Micron is 1 million'th of a meter.
    Millimeter is 1/1000 of a meter
    millimeter to decimal is mm * 25.4 = 1.000 inch
    so , if I did my math correctly (there is some doubt) 25,400 microns to the inch
    PICs in P basic Pro only do Integer Math.
    16 bit data bus only holds 65535 data bits.
    Seems as though a PIC should hold about 2.58 inches worth
    Do a search on DIV32, Darrel and some others have many threads and ideas.
    JS
    Jan 2007
    Default Micron to Decimal Conversion
    Thank You
    Charles at microEngineering gave me a solution
    and thank you very much for sharing that with us !
    Jan 2007
    Default micron to decimal conversion
    Charles first sent this email
    and the followed up with the second email
    First Email:
    If you'll give me a more specific example of the math, I may be able
    to help you with a method. The solution depends mostly on the range
    of measurement (the maximum count from the encoder).
    Can you just scale everything up to work in Word variables? If all
    you need a resolution of .001, you can use a 16 bit integer to hold a
    number up to 65.535.
    In this case, the math to convert the encoder count to the scaled
    decimal would be:
    decimal = count ** 25802 ' same as (count * 25802 / 65536)
    See the Upper 16 multiply operator (**) in section 4.17.1 of the
    manual.
    Since the count can't be allowed to exceed 65535 in this calculation,
    the resulting scaled decimal number will max at 25801 (25.801).
    This same method could (probably) be expanded to use 32-bit numbers.
    If you can help me understand what you need, I can either give you
    some math or estimate consulting time to do it for you (depending on
    the scope). Shoot some holes in my method above and I'll try to
    overcome.
    Charles Leo
    microEngineering Labs, Inc.
    http://microengineeringlabs.com
    Second Email:
    The ** operator multiplies two 16-bit numbers and then returns only
    the top half of the 32-bit result.
    You can think of this as a normal multiply that has a built-in
    division by 65536 to shrink the number into 16-bits.
    x = y ** 25802
    can also be written (outside of PBP) as:
    x = (y * 25802) / 65536
    Since you needed (x = y * .3937), I did the math to come up a number
    that would equal .3937 when divided by 65536:
    x / 65536 = .3937
    Solving for x, the result is 25801.52. Rounding to the next highest
    integer yielded 25802.
    Charles Leo
    Thanks to all
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 01:48
  2. Decimal to fraction conversion
    By tico in forum mel PIC BASIC Pro
    Last Post: - 29th April 2007, 16:54
  3. Help for decimal conversion
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 18:20
  4. Decimal to Binary Conversion
    By schlaray in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2006, 14:58
  5. Decimal to binary conversion
    By Demon in forum Code Examples
    Last Post: - 25th February 2005, 20:05
