LCD problem on portC
Results 1 to 6 of 6
    Mar 2006
    Unhappy LCD problem on portC
    I have had a 16x2 LCD display attached to a 16F877 to port A and is works just fine using the default settings for data port etc. The problem is that I have to move it to port C to allow me the use of the A2D converters on the chip. I have tried to assign the port and simply duplicated the wiring to the new pins (left the old ones attached for comparison reasons) but the display will not work.
    Is this correct?
    Portc.0 to portc.3 = data lines.
    PortD.0 = RS
    portD.1 = E
    DEFINE LCD_DREG PORTC
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTD
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTD
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    Why would this not work?
    unless you misswired smething, there's no reason
    i just tried it here... work a treat.
    Mar 2006
    Thanks Mr E.
    Ill double check the wiring tonight but as I simply duplicated it from one port to another (and left the previous wires intact for checking against) I doubt that I miss-wired it.
    I will check the connections with a cro tonight adn see if signals are getting out.
    Did you do anything else (initialise the port or something)
    nope, just placed a PAUSE 500 before the first LCDOUT.
    lucky guy you are, i still have what i used...
            @  __CONFIG _XT_OSC & _LVP_OFF
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    lcdout $FE,1,"hello"
    stop
    Mar 2006
    Cool
    Ill try again tonight.
    Mar 2006
    Smile Thanks for the assistance.
    Problem solved.
    I moved it to another port.
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 09:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 20:48
  3. PIC HSERIN problem
    By shaiqbashir in forum mel PIC BASIC Pro
    Last Post: - 20th July 2008, 12:08
  4. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 02:31
