DMX512 Problem ..Schema+Code
Results 1 to 22 of 22
    Mar 2007
    Default dmx
    hi friends i search in the forum and found many examples thanks. i have pic 16f876 , 20 mhz osc and 1 led ,i have dmx512 lighting desk too and i want to dimm a led on dmxadres 1 (0-255 to led intensty) but there is some problem on this code it is not working. i found this code in the forum and made it again for my pic but couldnt find the problem.can you look to my code and say what is my problem here?or you can send other example code to receive dmx ..
    ' PIC 16F876 - 20MHZ OSC
    DEFINE OSC 20 ' 20 MHZ OSC
    DEFINE HSER_TXSTA 24h ' Enable transmit
    DEFINE HSER_SPBRG 4 ' 250 000 Baud @ 20MHz, 0.0%
    ERRORLEVEL -306, -302
    ADCON0 = 0
    ADCON1 = 7
    counter var word
    idleflag var word
    dummy var word
    RCIF VAR BYTE
    startcode var word
    aminus var word
    adress var word
    x var word
    level1 var word
    adress = 1 ' My Start Adress
    checkdmx:
    counter = 1 ' Dummy variable
    pulsin portC.7,0,counter 'Here looking for the break signal
    if counter = 0 then
    idleflag = 1 'either no dmx , or break was too long to count
    'return
    if counter < 40 then checkdmx ' watching for "break"
    dummy = RCREG
    dummy = RCREG
    SPBRG = 0
    TXSTA.2 = 0
    TXSTA.4 = 0
    RCSTA.7 = 1
    RCSTA.6 = 0
    RCSTA.4 = 0
    RCSTA.4 = 1
    while RCIF = 0: wend
    startcode = RCREG 'firs byte after break
    if startcode <> 0 then checkdmx
    aminus = adress -1
    for x = 1 to aminus
    dummy = RCREG
    next x
    level1 = RCREG
    portC.1 = level1 'i want to dimm led on port c.1
    RCSTA.7 = 0
    goto checkdmx
    Jun 2005
    Wisconsin
    Angry
    Stop posting in multiple threads!
    Mar 2007
    Default dmx
    dear dynamoben here is a forum and we have to post something to learn.
    i make my code change and send it back why is it problem for you here is a forum and we have to post something you may not help just looking for a people that wo will find my problem to receive data no more.
    Quote Originally Posted by DynamoBen View Post
    How many other answers do we get to give before we completely give up?
  1. Loop with two motor and 2 sensors
    Last Post: - 7th December 2008, 14:17
  3. Making Program Code Space your playground...
  4. 4 Chanel Dmx512 ready assembly code to PBP ?
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 21st March 2007, 23:55
  5. Code problem
    Last Post: - 20th May 2006, 04:43
