DMX512 Problem ..Schema+Code
Results 1 to 22 of 22
    I already said...
    AND as you dont use any HSERIN/HSEROUT, the DEFINE HSER_xxx are useless. You need to write the right value directly to the SPBRG, RCSTA, TXSTA register
    so begin with...
    RCSTA = $90 ' Enable serial port & continuous receive
    TXSTA = $24 ' Enable transmit, BRGH = 1
    SPBRG = 4   ' 250 KBaud @ 20MHz, 0.0%
    Feb 2007
    Default Dmx Problem
    Dear Mister_e;
    yes many thereads in the forum but everybody has problem to receive dmx and nobody has succeed it..if you can writte and example here for us
    i know i have to use "hserin" command and it must be 250000baud it is not my problem i know them how to make..
    i want to see Code example to receive with "Hserin" Command.
    You said to me that i have to use "Hserin" Commmand For DMX receive But you didnt Writte it here ,
    How can i use it with 16f628A adn 20 mhz ;
    I didnt build my own master.(Transmitter) i use normaly device for lighting deskControl.and it works with dmx protocol .
    can you writte code here for how to receive it.
    i have standart dmx512 control device .. i need 512 receiver and it must be 3 chanel for my 3 leds you can look to my schematic
    Mar 2005
    CROATIA
    Default tx yes but rx hardly
    if you create asm sub (you can see i.ex manolator source@4mhz) and call that sub every time when you want to make output, must be carefull, timings are critical read the dmx protocoll
    another thing is dmx protocol is 250kb but is 11bit information with speciall startbit which is not standard. so forged using anny hserin or hseout exept if you can do some kind of hardware bit cutter/splitter-manipulator
    sorry for my english, im not shure that i'm uderstundible
    if someone is interested and able to programm DMX mini desk (i think can be done i.ex with 18f452) my wish is to see (and help)make those code (and schematic)
    Mar 2007
    Default dmx
    hi friends i search in the forum and found many examples thanks. i have pic 16f876 , 20 mhz osc and 1 led ,i have dmx512 lighting desk too and i want to dimm a led on dmxadres 1 (0-255 to led intensty) but there is some problem on this code it is not working. i found this code in the forum and made it again for my pic but couldnt find the problem.can you look to my code and say what is my problem here?or you can send other example code to receive dmx ..
    ' PIC 16F876 - 20MHZ OSC
    DEFINE OSC 20 ' 20 MHZ OSC
    DEFINE HSER_TXSTA 24h ' Enable transmit
    DEFINE HSER_SPBRG 4 ' 250 000 Baud @ 20MHz, 0.0%
    ERRORLEVEL -306, -302
    ADCON0 = 0
    ADCON1 = 7
    counter var word
    idleflag var word
    dummy var word
    RCIF VAR BYTE
    startcode var word
    aminus var word
    adress var word
    x var word
    level1 var word
    adress = 1 ' My Start Adress
    checkdmx:
    counter = 1 ' Dummy variable
    pulsin portC.7,0,counter 'Here looking for the break signal
    if counter = 0 then
    idleflag = 1 'either no dmx , or break was too long to count
    'return
    if counter < 40 then checkdmx ' watching for "break"
    dummy = RCREG
    dummy = RCREG
    SPBRG = 0
    TXSTA.2 = 0
    TXSTA.4 = 0
    RCSTA.7 = 1
    RCSTA.6 = 0
    RCSTA.4 = 0
    RCSTA.4 = 1
    while RCIF = 0: wend
    startcode = RCREG 'firs byte after break
    if startcode <> 0 then checkdmx
    aminus = adress -1
    for x = 1 to aminus
    dummy = RCREG
    next x
    level1 = RCREG
    portC.1 = level1 'i want to dimm led on port c.1
    RCSTA.7 = 0
    goto checkdmx
    Jun 2005
    Wisconsin
    Angry
    Stop posting in multiple threads!
    Mar 2007
    Default dmx
    dear dynamoben here is a forum and we have to post something to learn.
    i make my code change and send it back why is it problem for you here is a forum and we have to post something you may not help just looking for a people that wo will find my problem to receive data no more.
    Quote Originally Posted by DynamoBen View Post
    How many other answers do we get to give before we completely give up?
  1. Loop with two motor and 2 sensors
    Last Post: - 7th December 2008, 15:17
  3. Making Program Code Space your playground...
  4. 4 Chanel Dmx512 ready assembly code to PBP ?
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 00:55
  5. Code problem
    Last Post: - 20th May 2006, 05:43
