DMX512 Problem ..Schema+Code
Results 1 to 22 of 22
Threaded View
  1. #2
    DMX baudrate is 250 000 Baud, 9600 will never ever work.
    AND as you dont use any HSERIN/HSEROUT, the DEFINE HSER_xxx are useless. You need to write the right value directly to the SPBRG, RCSTA, TXSTA register
    AND @4MHZ... good luck to have a reliable 250K baud serial comm. 12MHZ and up will work.
  1. Loop with two motor and 2 sensors
    Last Post: - 7th December 2008, 15:17
  3. Making Program Code Space your playground...
  4. 4 Chanel Dmx512 ready assembly code to PBP ?
    By syscoder in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 00:55
  5. Code problem
    Last Post: - 20th May 2006, 05:43
