understanding the pulse.
Results 1 to 37 of 37
    because you're lucky?
    look at the datasheet, the min voltage to be considered as HIGH level is written somewhere.
    Are you talking about VIL and VIH?
    If so that means there have to be a 2V swing...
    Thats to tell if its high or low, im not sure this is the same thing.
    I have seen many other people using pics to decode the signal from a R/C receiver. The output of the receiver signal, the pulse width is no where near even half a volt.
    I have done this with a 270mV signal on over 50 chips so im either really lucky or something else.
    Again im new to all this but like I said I have never had any problems reading a pulse width off a rc receiver and thats at 270mV
    any model or datasheet for your receiver? Is it possible that it's open-drain output type? what happen if you place a 1-10K pull-up resistor on it's output?
    And yup it's Vil and Vih. it may differ from one i/o to another depending if it's an TTL or shmitt trigger one.
    0.3 v seems realllllly low to me. If it works... maybe your scope miss some noise or maybe you have some better receiver / pic.
    still thinking you're lucky
    No I don't have a datasheet for either Receiver.
    I don't know what open-drain output type means
    1K resistor made no difference using pulsin.
    Red face
    I'm so stupid...
    I didn't have the input pin set as input, works fine now
    Quote Originally Posted by geckogrotto View Post
    I'm so stupid...
    I hate it when that happens
    s h i t happen
    don't worry, it happen to everybody one day or another... expert or newbie...
    here's a few explanation of the open-drain output
    http://en.wikipedia.org/wiki/Open-drain
    http://www.acroname.com/robotics/inf.../opn_clct.html
    Thanks for the help guys hehe, question tho I was reading the voltage with a scope I thought that would give me an accurate voltage?
    -> If so that means there have to be a 2V swing...
    The difference between VIL and VIH is dependant upon the type of circuitry involved...generally speaking:
    CMOS: 0= <1/2 Vdd, 1= >1/2 Vdd
    TTL: 0= <.8v, 1= >.7Vdd
    -> the pulse width is no where near even half a volt.
    Pulse width is measured in time, not in quantity. If you are putting a meter on a line with a signal meant for a servo, what you are actually reading is the average DC voltage on that line. And 300mV seems about right consider that the signal isn't constant (50hz give or take) and is only around 1.5ms during those times.
    -> I have done this with a 270mV signal on over 50 chips so im either really lucky or something else.
    You probably haven't been measuring a 270mV signal. As stated in the paragraph above, you've probably been measuring a signal that swings from 0v to 5v, with an average DC value of 270mV.
    -> Again im new to all this but like I said I have never had any problems reading a pulse width off a rc receiver and thats at 270mV
    Again, R/C receivers don't output a signal that's around 270-300mV. It's definetely a signal that's repeating at a rate of 50hz, for about 1.5ms for every repitition. So if we do a bit of math on that...
    50hz = one signal every 20ms. A centered servo wants a signal of around 1.5ms, generally between 1-2ms. Therefore, over a second, the total amount of time, on average, with a pulse width of 1ms, this signal is reaching 5v is about 20ms.
    20ms out of 1000ms = (5v * 20ms) + (0v * 980ms) = .25V on average.
    Does that work for you?
  1. Pulse Capture and byte building
    Last Post: - 21st July 2009, 02:59
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. Replies: 3
    Last Post: - 13th September 2008, 18:40
  4. Better understanding PULSIN
    By Wirecut in forum mel PIC BASIC
    Last Post: - 29th June 2008, 11:17
  5. Pulse Frequency Multiplication
    Last Post: - 21st August 2005, 11:39
