What version of PBP are you using?
Are the PulselenX variables bytes or words? Probably should be words...
Are both of your grounds (the PIC and the signal being checked) connected? Probably can't check another signal with one wire, gotta have a common ground.
How fast is your OSC? The pulsin command might time-out before the pulse ends or the pulse width might be too long, both possibly because your OSC is too fast.
I suppose it would only work if that 300mV of change is right near the TTL low-high switch point.
