Bird sounds???
Results 1 to 5 of 5
Thread: Bird sounds???
    Oct 2006
    Smile Bird sounds???
    Hi guys,
    Is there anyway diagrams to make a bird sounds with a 16f628?
    This would be great if i could see the code in pbp before it has been compiled to hex.
    Thanks so much
    Regards.
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by guest_05 View Post
    Hi guys,
    Thanks so much
    Regards.
    Sure can. The SOUND command is right there waiting to be used.
    But what does a bird sound like on a PIC?
    i guess it would depend of the bird type. Some are easy to reproduce.
    At least record it, use a wav editor to determine the frequency and the duration of each different sounds/freq sweep... if any.
    Oct 2006
    Cheers guys.
    It was the diagram more then anything i would like to see how to set it up.
    I didnt think a pizzo could make a tweating bird sound, it sounds a bit mechanial.
    Cheers.
    To me a LM386 and a speaker will cover many possibilities.
    Depending the volume you want to have, a single 10-47uF capacitor between a PIC i/o and a speaker could also work.
  1. comp music with pic Sounds - Aka BeepMaster
    By flipper_md in forum Code Examples
    Last Post: - 20th September 2010, 07:04
  2. Audio sounds
    By Christopher4187 in forum Off Topic
    Last Post: - 2nd April 2009, 00:48
  3. PIC16F877A with 10MHZ quartz
    By oslinux in forum General
    Last Post: - 13th March 2007, 17:00
  4. Sounds???
    By guest_05 in forum mel PIC BASIC Pro
    Last Post: - 8th December 2006, 16:37
  5. R2D2 Sounds
    By DanPBP in forum Off Topic
    Last Post: - 11th October 2006, 19:11
