Problem to read a PCF 8574
Results 1 to 6 of 6
    Jul 2005
    Ferrara - Italy
    I2Cread SDA,SCL,%01110001,[DATAPCF]
    depending if you're using an A version the control byte may differ.
    Assuming your 4.7K pull-up (or lower) are on the I2C BUS, and you also have some on the PCF i/o... it should work.
    if i remind correctly, prior to be able to read read from this device, all i/o have to be at high level.
    i know i forgot something...
    Dear Steve!
    Thank you very much! I have resolved my problems! The problem was in the resistances from 10k that had inserted in the bus I2C, that didn't give some problem in writing but they didn't allow the reading! Have replaced her with two resistances 4K7 and the problem has been resolved!
    Bienvenue et bonne chance!
  1. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  2. write -read problem?
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 30th August 2009, 14:06
  3. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 12:20
  4. EEPROM Read problem
    By Christos_K in forum mel PIC BASIC Pro
    Last Post: - 5th June 2005, 18:10
  5. Replies: 8
    Last Post: - 11th November 2004, 21:08
