PIC sinking voltages higher that Vdd???
Results 1 to 31 of 31
    Quote Originally Posted by manumenzella View Post
    Hi. First of all, I want to say sorry if this is already posted, but I tried searching with no luck. I would like to know if an IO of a PIC can source a higher voltahe than Vdd. For example: PIC running at 5v, and a piezo running from 9v unregulated directly from a battery. In this way, the piezo will sound louder, right???
    Also, i think i might need to use a small diode in the IO, because, even if the IO is high , there will be some voltage difference with the battery voltage, and the piezo will never come back to the "resting" position, right.
    Thanks for your work, and sorry for my english.
    Manuel
    Look on any PIC datasheet...do a search for the term "Electrical Characteristics", there you will find your answer.
    Jan 2007
    Thanks a lot
    I will look it right now!!!
    Thanks again
    Manuel
    Jan 2007
    Hey. Sorry to bother you again.
    I have just looked in Electrical Characteristics, but i cant seem to find my answer I think it might be the thing called "clamp current" or sth. but im not sure. I tried looking it up by Google without any luck, too.
    Can you please tell me the parameter i should be looking for please???
    Thanks in advance!!!!!!!!
    Manuel
    Manuel,
    All you need is a general purpose NPN transistor, and a 10k resistor.
    10k from pic pin to the base, emitter to vss, collector to piezo, other side of piezo to +9V.
    Setting the pin HIGH, will turn on the buzzer.
    HTH,
    Manuel what kind of piezo do you talk about? Those 'plug and play' or those you MUST produce a tone to hear something?
    For high current, Darlington can be nice in some case, but they usually switch slowly and many have a BIG voltage loss between Collector and Emitter (few volts or so). I prefer MOSFET.
    malc-c's Avatar
    malc-c Guest
    Good comment regarding the MOSFET's, some of which have a low enough gate current so they can be driven direct from the PIC
    Depending of the load and frequency (if there's any), yes.
    For much demanding stuff, there's still the MOSFET driver solution. Tons of different models and type available. Microchip TC1427 are not too bad.
    Manuel
    1st page of that section, on the datasheets I've looked at so far, it's usually the 3rd parameter.
    malc-c's Avatar
    malc-c Guest
    Typing something like "driving piezo buzzer from pic micro" into Yahoo returned some interesting hits.
    http://www.talkingelectronics.com/Pay/PIC/P6extra.html
    I wouldn't expect the Piezo to draw much current, so a single transistor as DT suggested would be fine. If you want to drive things like motors then you could used an H-bridge or a Darlington power transistor.
    For your Piezo you could omitt the 18R resistor and output transistor, and connect the buffer transistor's emmiter to the 12v (or 9v in your case) supply
    More info can be found at http://www.talkingelectronics.com/Pa...PIC-Page3.html which explains the reason for using two or more transistors for high current loads.
    Hope this helps
  1. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 10:34
  2. 12 bit or higher ADC on a PIC that works with PBP?
    By Brandon in forum mel PIC BASIC Pro
    Last Post: - 11th November 2007, 17:19
  3. Replies: 3
    Last Post: - 29th October 2006, 09:16
  4. Replies: 2
    Last Post: - 10th February 2006, 01:04
